No worries... the only bad question is the one you don't ask.
The metal terminals are a press-fit into the plastic connector housing and are held in by:
- a (usually green or blue) plastic locking strip
- little metal tabs on each side of the metal terminal itself
So, to remove the terminals you:
- slide out the green/blue plastic locking strip with a thin flat-blade screwdriver
- insert a terminal removal tool into the front of the connector housing... this presses the metal tabs in and allows you to withdraw the terminal
- remove the terminal from the back side of the connector.
Assembly is simpler... the metal terminals simply press into the back of the connector housing with a slight click as the tabs bite, and then you re-install the locking strip
Princess Auto sells terminal removal tools:
https://www.princessauto.com/en/detail/2-pc-wire-terminal-and-trouble-code-tool-set/A-p8006462e
Canadian Tire might as well, can't tell on their gawd-awful web site.
Or, if you're not a fan of buying tools for the long haul VW will sell you a new turbo-specific connector housing to go with the repair wires... probably half the cost of the terminal tool, but of course it's a one-of.
It's the usual story... if you're planning on wrenching on VWs (or any vehicle for that matter) over time you'll be confronting broken wires on terminals, and the tool might be a good investment. Otherwise, for a one-of, just buying a new housing might be the way to go.
The bigger terminals can sometimes be unlatched with a couple of paper clips, but the turbo wires are pretty tiny suckers... maybe a couple straight pins would work? It' already busted... can't bust it more by trying?!
