I think it's dangerous to post anything that was related 3rd-hand. Critical details about the failure can get confused in the re-telling. Sadly, we have enough first-hand failures reported here, and even then, the details can get distorted.Within a mile after filling up at the same station she allways filled up at it lost power, a dash board light started flashing, and it died just as it got on a 4 mile long bridge. That's all I know by listening to a co worker about his wife's cousin's wife.
I have yet to hear of a CR Diesel from Ford, Chevy, Dodge, John Deere, CaseIH, Cummins HD, Detroit, have the same problem that VW is having with there fuel pumps.DasTeknoViking: > Find a gasser Jetta and do your own swap, called a BKD...
I'm not equipped to do that. If I were, I'd have already put a 5-speed in my ALH and called it good. The regional guy who does this sort of work doesn't do the hunter-gatherer part (finding donor parts), and I don't have the time.
Meanwhile, back at the thread topic, I was just looking at the 2012-11 letter VW sent to NHTSA. Here's an interesting section, from page 30:
"827 diesel fuel samples have been acquired throughout the continental U.S.
In respect to viscosity, 203 samples were out of ASTM specification (below 1.9 cSt), 186 of those were below the HPFP’s nominal threshold of 1.5 cSt. Here the HPFP may not have been properly lubricated.
59 samples were detected with lower lubricity (greater HFRR/WSD value) than required. 22 of them exceeded the HPFP’s nominal tolerance of 570μm and may have caused increased wear.
4 samples were found to contain increased amounts of water more than 1.5 % / 1.8% / 2.5 % and one sample exceeding 10% of water, which was not detected in the fuel station and random vehicle surveys. Viscosity and lubricity are within specification, but water could cause rust and corrosion in the HPFP and damage the pump.
79 samples contained more than 5% biodiesel, 20 of those exceeded 10%. Biodiesel itself does not damage the HPFP, however, collapsed/deteriorated/aged biodiesel can cause deposits inside the HPFP and clog filters, interrupting the lubrication and leading to failure.
252 samples showed a flashpoint below ASTM specification, but this has no direct impact to the HPFP’s durability and may just be seen as an indicator for possible gasoline content."
Yes, US diesel, at the station pump, is frequently way out of spec and/or contaminated. What's unsaid, of course, is that TDIs prior to the CRs had, and still have, no problem running on this bilge.
The CR situation appears to be due to a perfect storm of:
a. tighter requirements on vehicles, compounded by
b. a market roll to ULSD, which included
c. having to add lubricity agent at the terminal, plus
d. some states mandating biodiesel, sometimes more than 5%
VW and Botch designed to the ASTM spec, and not the US reality.
4 years later, the problem still festers.
Yes, I'm sticking my nose into this one. From reading TDI2000Zim's posts about his "HPFP failure", I'd like to offer that the jury is still out re: whether or not it was an HPFP failure. YES, he has an invoice that shows the HPFP was replaced, BUT, the circumstances surrounding the replacement are sketchy: for example, they didn't drain his fuel tank, it doesn't appear any lines were replaced/flushed, no inspection of the lift pump, etc. etc. In other words, this failure doesn't sound anything like the catastrophic failures in this thread. They simply replaced a "failed" HPFP.When you say, BLEW, did it actually explode?
I want to know, because the HPFP in my car was replaced yesterday, and it never blew up to begin with (and since the fuel wasn't purged, contamination is not an issue... yet).
Would the metal shavings be attracted to a rare earth magnet and if so, could a fuel line made of these magnets be incorporated inline before the injectors?The descriptive terms are hyperbole.
What happens is that metal shavings come off the failing parts, and are scattered throughout the fuel system, clogging the injectors. When not enough fuel is being delivered, the engine stops. There is no actual explosion taking place.
Parts of the HPFP are steel (ferrous), but parts of it are aluminum. The aluminum bits will not be attracted to magnets, so this would be only partially effective (at best). This idea has been brought up before and dismissed as non-effective. There are several threads here about the use of filters to limit damage, which would probably be more effective.Would the metal shavings be attracted to a rare earth magnet and if so, could a fuel line made of these magnets be incorporated inline before the injectors?
Do a Google search for "Ford HPFP failures". The CP4's are failing on Fords as well as other brands. Ford has particularly bad problems. CP3's on Dodge Cummins seem to have a better track record. To make matters worse, Ford is (or was) denying warranty claims on the pumps claiming that "contaminated fuel" is causing them to fail.I have yet to hear of a CR Diesel from Ford, Chevy, Dodge, John Deere, CaseIH, Cummins HD, Detroit, have the same problem that VW is having with there fuel pumps.
You won't find many heavy equipment failures due to the fact that commercial duty engines tend to use engine oil lubricated parts to generate injection pressures and not fuel lubricated parts. (Huge difference). I've also heard that some heavy equipment manufacturers require lubricity additives for remanufactured pumps in order for the parts warranty to stay in effect.
I think Bio is a mixed bag. Yes it increases lubricity, but Bio and water contamination seem to go hand in hand. I've seen pictures of pitted aluminum bores in CP4 pumps. Something has to be corroding those bores that have pitting.Ford is also denying fuel system replacement with any amount of bio in it. Even though the truck says b20 on the side.
glad the internet exists to correct autocorrect mistakesIn post 4858, Luked said "All pumps should have the phone number of whomever the local regular is."
What's a "local regular"? Could you possibly have meant "regulator"?
If not regulator, what?
Another problem besides water with bio is PH..... acidic= ferris metal corosion and basic= non-ferris metal corrision when water is present in the fuel.
properly stored ASTM biodiesel has none of these issues.I think Bio is a mixed bag. Yes it increases lubricity, but Bio and water contamination seem to go hand in hand. I've seen pictures of pitted aluminum bores in CP4 pumps. Something has to be corroding those bores that have pitting.
people putting homebrew slop and year old cloudy water saturated biodiesel in their cars get what they deserve, imo.
