Old September 10th, 2011, 07:31   #1
heartlandcycle
TDI(s): 99.5 jetta
Fuel Economy: 48-53
Default Help with VCDS test
2000 golf, 1.9 alh man. trans. Please tell me how I can perform a complete output test. When I get to the fuel shutoff segment, I have to restart the car and then the output test starts over. I cant get past the fuel shutoff window. I think my N239 valve is bad Thanks
heartlandcycle is offline   Reply With Quote
Old September 10th, 2011, 12:13   #2
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
that is normal, iirc the rest of the test doesn't require the motor to be running.
Check this forum for methods to test individual components:
OBD Scanners - TDIClub Forums
Old September 10th, 2011, 15:49   #3
heartlandcycle
TDI(s): 99.5 jetta
Fuel Economy: 48-53
Thanks for your reply Bob, I also have found a helpful link on the ross tech site. http://www.ross-tech.com/vcds/tour/out_test.html
Should have done my research b4 post. Hope that it may help other members.
test N75 > VCDS > Measuring Blocks > Switch to basic Settings > "Greyed Out" Ghastly OBD Scanners 53 July 17th, 2018 12:49
How to test CEL with VCDS? dkuster OBD Scanners 12 January 25th, 2011 08:46
Question on VCDS "Shutdown" Output Test Turbosprezarka VW MKIV-A4 TDIs (VE and PD) 14 February 9th, 2010 10:45
VCDS Earns Highest Score in German Scan Tool Comparison Test tommyt OBD Scanners 7 April 10th, 2009 06:40
VCDS Test Mode - N75 Duty Cycle TDIsyncro OBD Scanners 3 December 7th, 2008 09:43
Page generated in 0.11777 seconds with 11 queries
[Output: 56.97 Kb. compressed to 51.78 Kb. by saving 5.19 Kb. (9.12%)]
