VA Jetta
Ya, know I like my car. I like the way it drives, I love the distance I can go on a tank of good ole' D2, and I even like the way it looks. However after this I'm wondering if I should dump it. While driving on dry paved road the other day the ESR and ABAS Lights came on, then they went off and then came back on. So I hit my ESR button to turn it back on, but it didn't work. Then I disconnected the battery to see if that would reset the light, but as I expected the computer onboard is pretty self sufficient and the lights did not reset. Now I had a "red" steering light that would not go out. I took it to the dealer yesterday and here is what is wrong.
I have a bad speed sensor, the ABS and ESR sensors were bad, the break pad indicator light is also bad, my fuel door hardward fell apart and that's why the button inside does not work, I have two screws missing from the doors and from the 1st time they seemed to say that the turbo sensor came up as well when they hooked it to the computer so they may replace that as well.
If the car was still not under warrenty I would have spent well over $1,000 to get things working as they should be. I have 10,000 miles left on the warrenty and am thinking that these "problems" will keep popping up costing me any savings I have made in gas. I was hoping I could get 250,000 miles out of the car. Right now I'm hoping I can get 50K without some major delimma. I do the maintence as I should. I always buy fuel from reputable places and used Stanadyne. I buy the "good" oil, and I'm on this forum almost once a day to see what is going on and to learn.
I've never had a vehilce that I have had to put in the shop twice within the first 50K and I'm at 26K and have been there twice already. I can't even really say I'm fustrated or pissed off. What I can honestly say is that I am concerned about what maintence issues will come up in the future. Hopefully a few of you have had similar experiance, but they have worked out and now have 200,000 miles on your car. That's what I'm hopeing for me.
Mike
Front Royal, VA
Mike
Front Royal, VA
