Old January 4th, 2018, 06:42   #1
0die
Default typical steady state boost & pyrometer reading/value???
curious as to what a typical gauge reading should be...yes I know "typical" is a very relative statement...lol
Lets just say "steady state" conditions...say 75mph, cruise control on, flat highway...very boring, constant, cross country interstate driving...no hills, curves, passing, etc.....yes, we have all been there, many times.
I would think that is about as close to "controlled, laboratory conditions" that we can achieve on the road....
what are y'all typically seeing your boost and pyro gauges hovering around?
1996 Passat wagon TDI
assorted gas powered crap and motorcycles
RIP...countless Mercedes, Isuzu and other random diesels
0die is offline   Reply With Quote
Old January 4th, 2018, 07:39   #2
Yblocker
TDI(s): 1997 Passat
I'm at about 7-8 psi at 75 mph.
K03/04 hybrid turbo, RC II, Stage II Cam, Titan 502's, DC Stage I, TT LCA bushings
Yblocker is online now   Reply With Quote
Old January 4th, 2018, 09:29   #3
0die
OK...I just finally installed a set yesterday and will be on a long, boring trip. so figured would be a good time to see what it reads and if it's in line with what would be expected...or to at least establish a reasonable "base-line"...
basically looking for a "target value/range" I should expect to see under a specific, long-term, constant condition....
not every car is identical, but they should all fall within the a similar boost/temp range for a given condition constant speed/engine load/road condition. It seems on the interstate, just cruising along, is the best "universal setting"
Old January 9th, 2018, 08:14   #4
0die
looks like mine is around 10 psi at 75...running on uber flat roads...
Old January 10th, 2018, 11:02   #5
Steve Addy
TDI(s): 97 Mk3
I was going to suggest that 10psi was pretty close to what I see for flat non-wind conditions.
Steve
You didn't poison the coffee, did you? Not anymore than I usually do.
Old January 10th, 2018, 13:01   #6
Yblocker
TDI(s): 1997 Passat
Yeah, although I said 7-8 psi in my earler post, that's at an indicated 75 mph. At 80 indicated and close to 75 actual, I'm closer to 9 psi.
Old January 11th, 2018, 12:15   #7
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
flat ground multiply speed by 10 to get approximate "normal" pyrometer reading
75mph = 750F etc
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old January 12th, 2018, 08:31   #8
0die
sounds good...Mine was running around from 500-600F at 75-80ish....but I tapped into the 5th injector hole (cause it was already there) so I'm sure I'm reading a couple hundred lower than actual temps...
If I ever happen to have the ex manifold off I'll drill it for a better probe location...
Old January 13th, 2018, 10:02   #9
greenskeeper
Fuel Economy: 53mpg
If you don't have an EGR cooler a good location and easy access is at the top of the exhaust manifold centered at the turbo connection. Use a little grease on the drill bit and you don't even have to pull anything. That's where I put mine on my old 98 Jetta.
Old January 16th, 2018, 07:09   #10
0die
grease??? so it captures all the shavings?
Old January 18th, 2018, 12:33   #11
greenskeeper
Fuel Economy: 53mpg
yes, or you can disconnect the turbo and related components.
Old January 18th, 2018, 16:03   #12
ToddA1
Fuel Economy: Dismal
Or leave the engine running to help blow the shavings/chips out. Partially plugging the exhaust may not be a terrible idea.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
FS:BNIB Boost Gauge & Pyrometer Bambaataa Ontario 0 December 12th, 2012 20:14
Steady State Boost DieselCG VW MKIV-A4 TDIs (VE and PD) 20 May 31st, 2009 07:22
97 Passat Shudder during steady state driving bigtom111 VW MKIII-A3/B4 TDIs 7 December 12th, 2006 06:23
Steady State boost at altitude? wwhalenc VW MKIII-A3/B4 TDIs 8 April 21st, 2004 19:23
Pyrometer & Boost Gauge sensor locations Jet-01 Upgrades (non TDI Engine related) 1 August 6th, 2001 20:16
Page generated in 0.17163 seconds with 12 queries
[Output: 107.61 Kb. compressed to 90.24 Kb. by saving 17.37 Kb. (16.14%)]
