Diesl
- Joined
- Dec 3, 2012
- Location
- Chicago
- TDI
- '78 Golf Diesel (long gone); 2012 Jetta Sportwagen TDI w/ DSG
According to that VW NHTSA filing that Darrell linked above, the failure rate is 2.7 per thousand total, and about 1.5/1000 (might remember the number wrong, but thereabouts) of that due to the high pressure fuel pump, with most of that due to an initial bad batch of high pressure fuel pumps.
For the later cases, the filing claims that only in 6 out of 49 cases investigated there was no gasoline (or an insignificant amount) found. In 2 out of the 49 cases the dealer had introduced the fuel. 43 had on average 8% gasoline in the fuel. They state that 1% gasoline has been found to be enough to cause failure!! They also state that beginning of model year 2010, and again sometime late-2010 new surface treatments for the highly loaded parts in the high pressure fuel pump were introduced.
