Old May 14th, 2018, 09:44   #1
Krytie TV
TDI(s): 2006 Jetta
Default Engine blew? Can't diagnose yet, but have the symptoms.
Instead of spending my lunch break eating, I'm now wondering what I just blew in my 2006 Jetta BRM.
I usually get a puff of smoke on startup, but this time it was a bit more. I pulled out on to the road and right after shifting to 2nd, I heard a clunk, for lack of a better term. It's almost the sound you would hear if a large metal object was bouncing around in your hood compartment. Kinda like running over something. Car was shaking moderately and I was able to pull back in at about half-power.
Of course the weather today is awful, so I pulled back into work and popped the hood to find the bottom half of the engine soaked with oil, my antifreeze is draining, and a steady stream of oil is running down from the front/passenger side of my skid plate.
I'm assuming that it's my cylinder head, given the antifreeze issue. I'm wondering if anyone has any obvious diagnoses while I scramble to figure out what the rest of my day looks like. Any and ALL ideas are welcome.
Krytie TV is offline   Reply With Quote
Old May 14th, 2018, 09:49   #2
oilhammer's Avatar
Fuel Economy: fantastic
I should think the problem should be pretty obvious once you look.
I am betting by the sounds of it there is a rod that made a ventilation hole in the the block.
www.cardocautomotive.com
Old May 14th, 2018, 09:50   #3
Krytie TV
TDI(s): 2006 Jetta
That sounds poetically fatal.
Old May 16th, 2018, 21:04   #4
pedroYUL
pedroYUL's Avatar
Fuel Economy: ~17.5 km/L
I have a 2006 Jetta in need of a new body, but very solid mechanically. Let me know how this one turns out, maybe we can work something out.
pedroYUL is offline   Reply With Quote
ALH had been run low on oil... help me diagnose the symptoms that followed? ksmoker VW MKIV-A4 TDIs (VE and PD) 22 March 8th, 2015 09:36
Please help me diagnose my symptoms! dbdubb VW MKV-A5 Golf/Jettas 15 August 25th, 2011 17:56
Help Me Diagnose the P0299 Code - all symptoms solutions 98mkiv VW MKIV-A4 TDIs (VE and PD) 1 January 19th, 2011 20:18
Poor mpg, noise/tick/rattle symptoms help diagnose EECSentric VW MKIV-A4 TDIs (VE and PD) 8 April 16th, 2005 06:40
engine blew any help 22lr10xxx TDI 101 15 February 14th, 2005 06:44
Page generated in 0.12117 seconds with 12 queries
[Output: 63.94 Kb. compressed to 57.34 Kb. by saving 6.60 Kb. (10.32%)]
