panda
- Joined
- Jan 1, 2002
- Location
- Chichester, NH
- TDI
- 2002 Jetta, 2015 Golf Sportwagen, 2005 Jeep Liberty CRD
I've been trying to diagnosis a problem I've been having with my '02 Jetta TDI (http://forums.tdiclub.com/showthread.php?t=336357) that involves occasional heavy smoke/soot and low speed stumbling among other things. Since I've got 302,000 miles on the car i decided to replace the vacuum lines. Wow, I'm surprised the car ran as well as it did. I think it's likely there were multiple vacuum leaks.
My major discovery so far is that the ASV actuator doesn't appear to be working. The vacuum line was cracked and I thought that would be the end of it, but I decided to see if it would move with some vacuum. Surprise, surprise even with a new line and the Mitty Vac it will not hold a vacuum and doesn't open. Shouldn't I be able to get this to do something with the Mitty Vac. This may explain the clouds of soot that was ejected out the tail pipe the last time it ran in the garage. Maybe lots of vacuum would get it to open some but I can't hand pump the Mitty Vac that fast.
I realize it's job is to prevent run on but I can I live without it? I can only find it sold as part of the pricey EGR valve.
