Jaredmon
Thanks for all the help on getting this TDI back together. Engine runs great BUT.... driving is another story. We are not getting any power.
What we have done so far:
Cylinders honed, new bottom end, rings and top end. New seals and bushings in turbo. New fuel, oil and air filters. Egr block off plates and cooler removed. Intake man and egr pieces cleaned. Have not done any computer adjustments.
Again, no power is my issue.
Codes are coming back as:
P0122 TPS low input
P2413 EGR malfunction
P0401 EGR flow insufficient
P0671 Glow Plug cyl 1
I know I need to reprogram the ECU for the egr delete but would that be the only power issue? What causes the TPS code? Where is the TPS?
Thanks for the help.
P0122 TPS low input
