Old December 23rd, 2013, 12:43   #1
F2 Ed
F2 Ed's Avatar
Question ASV down on power
I've got a remapped ASV 110 that doesn't pull like it should.
No fault codes, no warning lights. Vagcom showed actual MAF & expected MAF data were different so suspected faulty MAF sensor. Replaced, but no joy
Its got some initial pull, can hear turbo working, but over 2,500rpm its flat. No pull at all up to the red line
Not dumping any smoke that I can notice either
What do you think? N75 valve? Turbo? Clogged inlet?
F2 Ed is offline   Reply With Quote
Old December 23rd, 2013, 20:01   #2
paoutdoorsman
Did you check the actuator valve for free movement with a vacuum pump? Where do you see actual and expected MAF data in VCDS?
paoutdoorsman is offline   Reply With Quote
Old December 23rd, 2013, 20:18   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
Does the maf actual meet the maf spec in the group 3 of measuring blocks in vagcom? A lot of reman or cheap mafs are bad from the shop, even bosch remans.
Seatman is offline   Reply With Quote
Old December 23rd, 2013, 23:57   #4
F2 Ed
F2 Ed's Avatar
data capture in 3rd gear WOT
Old December 25th, 2013, 13:06   #5
Lensdude_com
Lensdude_com's Avatar
Fuel Economy: 50 mpg average (Imperial)
Any chance you have a modified air-intake system that might be responsible for fouling your MAF sensor?
Have you checked the EGR/Intake Manifold for any flow restrictions from crud build-up?
Have you checked the Turbo Inlet Pipe connection to the turbo?
Lensdude_com is offline   Reply With Quote
Old January 31st, 2015, 08:26   #6
F2 Ed
F2 Ed's Avatar
Totally standard car. New MAF cured it
Old January 31st, 2015, 18:07   #7
Seatman
Seatman's Avatar
Cool, there seems to be a lot of dodgy new ones around, even bosch remans.
ASV low on power HiRoller TDI 101 0 May 15th, 2013 12:35
110 Tdi Asv with low power squeak VW MKIV-A4 TDIs (VE and PD) 0 December 2nd, 2011 11:56
GTB2056VK in to BRM - ASV or not to ASV??? A5INKY TDI Power Enhancements 13 April 23rd, 2011 08:38
ASZ return hose (power steering) instead of that of ALH (ASV, AHF, AGR) RomSL TDI Power Enhancements 3 January 7th, 2010 09:13
ALH to ASV conversion - Power Mod by itself? peter pyce TDI Power Enhancements 4 February 20th, 2004 20:02
Page generated in 0.14676 seconds with 11 queries
[Output: 78.56 Kb. compressed to 68.12 Kb. by saving 10.43 Kb. (13.28%)]
