tbones
- Joined
- Dec 22, 2005
- Location
- Annapolis, Maryland
- TDI
- 1996 Passat wagon tdi, 1991 Corrado TDI (sold)1983 Vanagon 7pass.GL 1.6td 1982 Westy;THE PHOENIX 1.6na(NOW JX/5speed) my partner's 2014 Jetta Sportwagon 6spd manual AND MY NEW TOY/PROJECT... Sunny, a bright yellow 87 syncro Westy with 1Z TDI motor
Thanks, I did the blend door repair last year, and yes it did fix interior heat issues.You might need to do the mode/blend door repair. If it's never been done you most surely need to do it. Look in the vents, see any foam in there? 190 degree thermostat will produce more heat than you ever need. There is a sticky on this. Large PITA to do. Mine took about 9 hrs. to do. Well worth the effort. Hot heat, ice cold a/c.
What I wish to fix is how damn to slow it takes for the engine to come up to operating temperature...this did not seem to fix that issue.
