Old November 14th, 2019, 01:30   #1
tom_h
Default PASSAT 2010 B6 wiper problem
Hello I'm new here....so I appologise if this is not the correct location for question about my 2010 VW Passat wiper motor....
I'm trying to fix a my front wipers which stopped working.
I took to a garage and they said it was the motor and said they could order and replace it.
The next they phoned and said actually they can't get the motor and I would have to contact VW.
So having had a diagnostic that the motor was shot, I found a second had one and replaced it......but no change.....still doesn't work
I'm now thinking that perhaps the garage didn't check properly and there is an electrical fault rather than a faulty motor (or else I have bought a broken motor)
Can anyone help with diagnostics?
I have checked the voltage to the connection at the motor and I have 12V (across the 2 larger diameter wires); This presumably means that the fuse is not blown.
I have this even when the key is not is the ignition, so I'm looking for guidance on what to do next, to locate the source of the problem.
Could someone talk me through what readings I should be getting at the connector on the wiper motor with the ignition on / off / wipers on etc
Is there are way to check that the 3rd smaller diameter (data) cable is providing the correct voltage? Is there another fuse for this cable?
Is there a way to check the motor?
Thanks in advance for any help
Tom
tom_h is offline   Reply With Quote
Old November 14th, 2019, 03:55   #2
tom_h
WIPER UPDATE: all working now - I was a bit stupid and was looking to see if the wipers worked with the hood still open!!!.
Old November 14th, 2019, 13:33   #3
Scubanero
Scubanero's Avatar
By way of explanation: When you turn the wipers off they keep going until they get to the park position, which is why you saw +12V even with the key off.
There are 10 kinds of people in the world: those that understand binary and those that don't.
Scubanero is offline   Reply With Quote
Passat B6 3rd gear problem Aato TDI 101 3 February 17th, 2018 14:43
Audi B6 long starting problem derekas Other VW Group TD(I)s 0 October 29th, 2012 07:20
FS: Passat CC TDI cluster - White display - to fit Passat B6 Jarek Private TDI Items for Sale/Wanted 2 December 28th, 2011 13:08
B6 Passat 2006 Tdi engine problem... Ashy TDI 101 36 June 27th, 2009 16:29
Front wiper problem turns out to be rear wiper connection corrosion, so check yours laminated VW MKIV-A4 TDIs (VE and PD) 2 June 12th, 2008 20:41
Page generated in 0.16518 seconds with 11 queries
[Output: 57.79 Kb. compressed to 52.54 Kb. by saving 5.25 Kb. (9.09%)]
