Old October 4th, 2019, 20:47   #1
Scubanero
Scubanero's Avatar
Default Brake rotor corrosion
I am curious to know if anyone else has experienced severe corrosion of their rear (and only rear) brake rotors. I have just put on my fourth set of rotors in 13 years and 270,000 km. The front rotors donít. Other vehicles at the same location donít. The car is driven regularly. It is a dry climate with low usage of road salt. The slide pins and pistons have always moved freely.
Three different brands of rotor including OEM have reverted to the oxide form prematurely. Most recently were Zimmerman rotors and Wagner ceramic pads. Typically a portion of the rotor face starts to rust and scrapes off the pad material at the rusty strip, which then grows slowly wider.
If you have seen this type of thing, have you found any way to prevent it?
There are 10 kinds of people in the world: those that understand binary and those that don't.
Scubanero is offline   Reply With Quote
Old October 5th, 2019, 14:31   #2
QuickTD
Here in the rust belt, it would have been 13 sets of rotors in 13 years. I have no sympathy for you...
QuickTD is online now   Reply With Quote
Old October 5th, 2019, 17:44   #3
afarfalla
afarfalla's Avatar
I've never had to change mine
afarfalla is offline   Reply With Quote
Old October 6th, 2019, 17:34   #4
Scubanero
Scubanero's Avatar
You canít scare me. I lived in Sarnia for a while. All of your brake rotors rust, though, not just VW rears.
Old October 7th, 2019, 13:31   #5
blazen71
blazen71's Avatar
Fuel Economy: 36.6mpg
Sometimes its associated with the pads getting stuck. Make sure the pads move freely.
I'm your Huckleberry
blazen71 is offline   Reply With Quote
Old October 7th, 2019, 17:18   #6
Scubanero
Scubanero's Avatar
Always were and still are.
1. There is always a clean friction zone that just keeps getting narrower.
2. Parking brake always works perfectly.
3. Pads get worn away quickly, fastest at the rust zone which gets a bit thicker as rust forms and erodes off.
4. All four faces are affected pretty much equally.
Old October 9th, 2019, 12:14   #7
imo000
imo000's Avatar
Fuel Economy: Good enough
Get better quality rotors.
imo000 is offline   Reply With Quote
Old October 9th, 2019, 14:08   #8
blazen71
blazen71's Avatar
That would be my guess, but the OP has used OEM and Zimmerman. Castings keep getting cheaper and cheaper.
Old October 10th, 2019, 08:14   #9
imo000
imo000's Avatar
Get OE instead of OEM.
Old October 10th, 2019, 09:15   #10
soot1
You may have pinpointed the problem exactly. Even some Zimmermans now have an imprint on the box that says "Cast in China, finished in Germany". What good is it that the runout on such rotors is below 0.0005", if the base material contains so much garbage that the rotors self-destroy after one winter?
soot1 is offline   Reply With Quote
Old October 10th, 2019, 13:48   #11
Scubanero
Scubanero's Avatar
I bought the car with 12000 km on it. The factory rotors did the same thing.
I have replaced the front rotors once and see far less corrosion on both OE and aftermarket, none on the friction face.
Old October 10th, 2019, 20:01   #12
Powder Hound
Powder Hound's Avatar
Back when I drove every day, my rotors lasted and lasted. Now that I'm working from home and many weeks go by where I drive 5 miles once during the week, and that's it, my rotors barely go a year, and less than 2k miles. I'm paying lots more for rotors than anything except fuel, insurance, and registration (taxes). Well, registration is neck and neck with rotors.
PH
Old October 11th, 2019, 16:24   #13
Scubanero
Scubanero's Avatar
PH
That is really excessive. Front and rear the same?
My Dodge pickup sits outside all winter with infrequent use and is still on the factory rotors with over 300,000 km.
Old November 17th, 2019, 19:18   #14
peteguenther
TDI(s): 2003 Jetta
Fuel Economy: 40 in the hils 50 on the highway
I'm seeing exactly the same on my '03 and others, most with cheap rotors. My last set have not even lased a year and 15k miles - the rears that is = fronts are fine and even the inner rear is not so bad.
peteguenther is offline   Reply With Quote
Old November 18th, 2019, 20:36   #15
Scubanero
Scubanero's Avatar
Thing is: even the factory rotors did the same thing, just as fast as the after-market ones. The rears rust away 2-3 times faster than the fronts and the inner face is just as bad as the outer. I am beginning to think that there is something a little different about the brake setup on these cars.
This go-round, I just replaced the rears rotors and used semi-metallic pads thinking that softer pads might make better full face contact with the rotors.
Unofficial 2016 MKIV Brake Pad/Brake Rotor Suggestion Thread Joester VW MKIV-A4 TDIs (VE and PD) 5 May 3rd, 2016 17:36
What a great brake rotor fireofficer001 VW MKIV-A4 TDIs (VE and PD) 35 June 8th, 2014 12:32
Chipped Brake Rotor blaz Ontario 3 April 19th, 2008 10:55
Brake Rotor Question Newgene VW MKIV-A4 TDIs (VE and PD) 27 June 26th, 2007 15:01
Brake/Rotor question Jeff_Duncan VW MKIV-A4 TDIs (VE and PD) 8 August 30th, 2005 08:23
Page generated in 0.16922 seconds with 11 queries
[Output: 127.31 Kb. compressed to 105.62 Kb. by saving 21.69 Kb. (17.04%)]
