Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old October 4th, 2019, 01:55   #1
77 K20
77 K20's Avatar
Default Bought a 2011 Touareg TDI, code P242A
It has been quite a while since I've posted to this forum. My 2000 Golf TDI and my 2005 Passat wagon TDI were both totalled by idiots running into me. My 2004 Passat TDI had 2 turbos blow in about a year and a half so I got rid of that car... but I missed TDIs a lot-
I found the 2011 in Portland which was an 11 hour drive from home for a good deal. Started driving it back early last Sunday in the pouring rain and about an hour outside of Portland the check engine light came on. It was running fine- checked the code and kept driving home.
P242A Exhaust Gas Temperature Sensor, B1 S3 malfunction. I tried to clear it, but it just pops back up immediately.
It has an appointment at the local VW dealer next week as they are booked until then.
Seems I've read that a lot of the newly fixed ones seem to have some issues for a bit until the "bugs" get worked out of them.
So far I really like it- with 3 adults and luggage on it I averaged 27.3 mpg on the way home. That involved 3 passes and cold temps with a lot of rain and some slush.
I'll post back here with what the dealer says since it should be covered by the emissions warranty.
2007 VW Touareg
2011 VW Touareg TDI Lux
2014 VW Passat 1.8T 5 speed manual
2003 Chevy 2500HD 8.1L 6 speed
1977 K20 Fuel injected HT383
77 K20 is offline   Reply With Quote
Old October 4th, 2019, 22:44   #2
77 K20
77 K20's Avatar
A small update- last night after work I got the diesel particulate filter warning light illuminated.
Called the dealer this morning and they wanted me to swing by to check to make sure my P242A code was valid and to order parts (if needed) for my appointment next week.
They found the same code. They were unable to clear it also. They didn't have sensors on hand so have to order it.
They say without a functional EGT sensor it doesn't go into regen and then the particulate filter will start to plug. Best not to drive it.
It is covered by the emissions warranty. They did not have any loaner cars to drive in the meantime though.
2007 VW Touareg
Old October 5th, 2019, 17:45   #3
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
Good thing for the warranty!
mannytranny is offline   Reply With Quote
Old October 7th, 2019, 12:43   #4
andreigbs
Without VW's warranty on these beasts, I don't think I'd ever be able to justify wanting one.
Let us know what they outcome is and what all they replaced.
2014 Jetta TDI // 45xxx miles // 38 MPG & 2014 GLK 250 // 113xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is offline   Reply With Quote
Old October 11th, 2019, 20:57   #5
77 K20
77 K20's Avatar
Got it back from the VW dealer today.
They replaced the EGT sensor. They said the wiring was fine- it didn't melt or anything. So it was replaced. P/N:059-906-088-BF
Then they forced it to do the regen and made sure the DPF cleared.
So I'm all good to go- no lights on the dash anyway.
2007 VW Touareg
Soooo, I bought a new '16 Touareg TDI volksjaeger VW Touareg TDIs 55 September 17th, 2018 09:42
2011 Touareg 3.0 - PO706 Code youngman TDI 101 1 January 1st, 2017 10:19
Bought 2011 Touareg 2 weeks ago G Aksland VW Touareg TDIs 14 March 9th, 2011 16:46
Page generated in 0.12974 seconds with 11 queries
[Output: 68.47 Kb. compressed to 60.36 Kb. by saving 8.10 Kb. (11.83%)]
