Engine is not getting the air it needs after turbo clean and injector rebuild
Updated 3/29 night
The harbor freight compression tester that I got the first time was missing the valves on the glow plug screw in adapters. The second one worked.
My compression's were 550, 500, 525, 525. cylinders 1-4.
All my inter cooler pipes seem to be intact and connected. I just took off the lower inter cooler pipe to make sure.
Any other suggestions on why my engine isn't getting the air it needs? I've tried two different MAF's and its not getting the air that is required.
Im pretty stumped. Thanks for any help.
Update 3/29
I tried a compression test. But I think the compression tester is broken so Im taking it back swapping it for another one at harbor freight.
The tester wouldn't go over 100 psi on any cylinder.
Here is a video of the tester not going over 100psi https://www.youtube.com/watch?v=crfg0_l8quQ
It doesn't seem like a hard process. Car was warmed up. Removed all glow plugs. Disconnected my injector pump. Found the adapter that fit in the glow plug slot and turned it in mostly by hand. PSI wouldnt build at all. I hope it doesn't mean there is something seriously wrong with the engine. I should have another tester to test tonight.
Updated 3/23
Well I just swapped maf's and nothing changed. Maf actual is not getting above 650 at most. I can rev to redline in neutral. Its blowing a ton of white smoke so fuel is not getting the air it needs.
What could be causing this? A clogged CAT?
Updated 3/22
My ALH still seems to be miss firing or at least the idle is dropping from 900 to like 850 every once and a while and the turbo logs look really bad. I think there is a boost leak but I’m not sure where to look. It’s putting out a good amount of white smoke not the black that it used to put out.
My boost gauge needle is very shaky like compression is being lost but I’m not sure where.
https://www.youtube.com/watch?v=mhMzvxLyY34
https://www.youtube.com/watch?v=HPX0DzXUMBg
Stock tune
Stage 3 looks awful....
I tried to log my MAF but my car wouldn't go over 3k rpms in 4th gear. But the actual at 2900 rpms was 600 when ross tech said at 3k it should be 800. But when I unplug my MAF my car runs get less boost for sure at least 3 psi less.
I don’t know where else to look.
Does anyone have any suggestions?
Update 3/20
The codes went away after tapping and torquing the injectors a few times. I took it out for an Italian tune up and the smoke stopped after a mile.
What are some things I can graph in vcds to make sure my car is running well? I'm not getting any codes. I had to adjust my IQ to 3.0-3.4 so it was running smooth.
It still seems to be putting out a little bit of white smoke. Cars are not going to be happy being behind me. But its not smoking at idle anymore.
Is it worth getting a 22mm wrench so I can adjust my timing and get it smack dab on the blue line?
Thanks for the help guys!
Update 3/17
Im waiting on an injector bolt to come in on Monday. I cleaned under my washers and used the tap down method on the injectors.
The thing that concerns me is that I got the misfire code before i got my injectors checked and rebuilt. Could a bad injector gum up the inside of my engine to the point where it cant get clean and needs to be cleaned?
All my spark plugs look good and all have the same voltage.
Opening post
Hey guys. I have a 03 alh and I had my turbo clog up recently and I cleaned it and I think it was clogged from one of my injectors leaking fuel.
I threw P0302 last week so I just had my injectors checked at a fuel injection shop and two of them had to be rebuilt. Today when I put them back in Im getting a ton of white smoke from the exhaust and as soon as I clear P0302 in vagcom it comes right back. My IQ is around 4-5 when it finally warmed up.
I have no oil consumption at all and my turbo was good after I cleaned it. It only had 50k miles on it.
Has anyone had this happen or have any ideas to what I can do or check next? The smoke might be excess fuel from the injector that wasnt working great so that might burn off eventually.
Timing
Updated 3/29 night
Update 3/29
Updated 3/23
Updated 3/22
Stock tune
Update 3/20
Update 3/17
Opening post
Timing
