Old September 5th, 2013, 20:04   #61
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Trans went in in March. There was a mileage jump then. Warmer weather compounded with the 6 speed would be May.
Not looking forward to winter.
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old September 14th, 2013, 16:13   #62
Uberhare
Uberhare's Avatar
TDI(s): Too many.
New clutch will be here next week! Time to pull the gearbox again...
Old September 14th, 2013, 16:35   #63
mrrhtuner
mrrhtuner's Avatar
Ouch.
How hard is it to take out the gearbox in the passat? Does it seem easier then the MK4 jetta?
mrrhtuner is offline   Reply With Quote
Old September 14th, 2013, 17:32   #64
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Depends which gearbox! I can yank this 6 speed in about an hour. (Don't ask me how I know)
The auto is a bit more work. You have to drop the subframe out of the way.
Old November 20th, 2013, 09:07   #65
Ropre
Jason
When pulling the auto tranny did you remove the subframe all the way, or just lower it? Meaning can you leave it attached to the lower control arms.
What clutch are you using now?
Thanks -Rory
Ropre is offline   Reply With Quote
Old November 20th, 2013, 09:09   #66
Sprocket
Sprockette's hubby
Sprocket's Avatar
Originally Posted by Ropre View Post
Jason
Thanks -Rory
No need to mess with the subframe at all. Clutch is a DC clutch. Whitbread can give you more details on it.
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old November 20th, 2013, 10:58   #67
Ropre
Really. Wow you can get to all the transmission bell housing bolts and remove the junkbox (auto) out without loosening the subframe at all? Cool
Yes I am currently in communication with Matt about buying a clutch through him.
Thanks again.
Old November 20th, 2013, 11:17   #68
DeliveryValve
Thanks again.
That is definitely not correct. I just did this job. Took a lot of pics, perhaps I should post them.
Anycase you HAVE to drop the subframe, not all the way, but enough to tip the ZF auto trans down to get to the bellhousing bolts. This requires removing the bolts in all four corners of the subframe and disconnecting the lower strut/shock mount, along with holding up the engine.
Now I heard with a manual, it is not needed to drop the subframe.
- Richard-
2005 Passat TDI GLS Wagon 21x,xxx miles - Chainless
DeliveryValve is offline   Reply With Quote
Old November 20th, 2013, 11:20   #69
vwztips
vwztips's Avatar
I have not managed to do that. my extensions do not bend like that. Not saying it can't be done.
vwztips is offline   Reply With Quote
Old November 20th, 2013, 15:24   #70
Ropre
Sorry Sprocket,
I ment the other Jason (uberhare)
Old November 20th, 2013, 17:37   #71
Uberhare
Uberhare's Avatar
TDI(s): Too many.
To pull the auto - drop the subframe. Doesn't have to come right out but drop it down out of the way.
The 6 speed is small enough it can be removed without touching the subframe. My Sachs racing clutch is sitting on the workbench waiting....Oh I miss 27 PSI.
Old November 20th, 2013, 17:45   #72
Uberhare
Uberhare's Avatar
TDI(s): Too many.
To further explain the clutch - I went with the stock DMF 240mm setup and a Sachs racing clutch. I actually spoke with a tech from LUK on the DMF vs SMF issue on these transmissions (and in general). If you measure the weight difference between a sprung clutch disc and unsprung, the difference is pretty significant. I went to the shelf later and verified...Yes pretty big difference. All of that extra rotational mass has to be slowed down by your syncro before it will engage the syncro hub. Your syncros will wear much quicker with all that extra force it has to "brake". Some domestics actually use a lining on the syncro gears similar to a brake material. Think if it like pulling a trailer all the time on your brakes. Extra load on every stop, they WILL wear much faster.
So I decided to stick to the factory DMF. We'll see how it holds up.
Old November 20th, 2013, 22:58   #73
Ropre
Ubershare-
What did you do to deal with the minimal pilot bearing engagement do to the 5.5mm spacer? What is your opinion of having the 6 speed box? Do you think you could have lived with just 5 gears and a slightly higher rpm on the interstate? If you can please try to answer this pretending the 5 speed box was just as stout as the 6 speed and could hold your 27 psi just fine? Thanks for humoring me.
Old November 21st, 2013, 06:20   #74
jonlowe
The 5 speed and 6 speed TDI boxes have the same final ratio, so the highway speed RPMs in top gear are the same. Intermediate gear ratios are different.
Jon
Ubershare-
jonlowe is offline   Reply With Quote
Old November 21st, 2013, 06:53   #75
vwztips
vwztips's Avatar
Jon
There is one exception that I know of which is the DQS gearbox. I do not know from first hand experience, but from what I have read here, it seems there are issues with the resonances in 6th gear due to the taller gearing.
There are plemty of threads and discussions here about the pros and cons of the 5 speed vs 6 speed. Personally, I am more than pleased with the 5 speed.
Planning 6-speed swap, so 5-speed swap is for sale Redneck Truck Private TDI Items for Sale/Wanted 0 February 13th, 2013 14:14
Coding/Login for BHW Manual Swap? alphaseinor OBD Scanners 2 August 10th, 2011 06:01
BHW Blown swap in another PD Engine? mogly VW B5 Passat TDIs 10 June 4th, 2010 13:31
BRM engine swap for BHW? TomB VW B5 Passat TDIs 31 October 28th, 2009 13:30
Does anyone know BHW manual trans swap FollowTheBlackRabbit VW B5 Passat TDIs 59 July 21st, 2009 11:33
Page generated in 0.20083 seconds with 11 queries
[Output: 129.50 Kb. compressed to 108.17 Kb. by saving 21.33 Kb. (16.47%)]
