Old June 11th, 2017, 17:10   #16
benIV
benIV's Avatar
you mean the 74? or the ants? lol
OCD TDICLUB MEMBER #6 - 2003 TDI Mafia Member
Orville, 2003 Jetta 5m Sedan, Platinum Gray
Wilbur (Knurren), 2003 Jetta 5m Wagon (Golf Variant), Reflex Silver
1974 Super Beetle Conv
1986 Mercedes 560 SL
1956 Chevy Truck - Hot Rod
benIV is offline   Reply With Quote
Old June 11th, 2017, 17:57   #17
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
And the second picture is my driveway, or used car lot, as my neighbor begrudgingly calls it. It's actually missing a few cars, but my 3 cars are there (bug, 560SL and Orville)
I see no second picture in your first post?
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old June 11th, 2017, 18:32   #18
benIV
benIV's Avatar
fixed
Old June 11th, 2017, 19:53   #19
aja8888
aja8888's Avatar
fixed
Very nice looking Bug!
Old June 11th, 2017, 20:40   #20
benIV
benIV's Avatar
thanks. as soon as i finish with Orville (the plat. grey jetta), the bug will be the next project. it has a lot of issues. For a long time my parents refused to keep it maintained and it had been neglected for 5 years or so. Nothing that can't be addressed and fixed. I'm looking forward to it. That bug is what I learned to drive in and it is what turned me into such a VW guy in the first place. My 1981 MB 300D turned me to diesels.
Old June 11th, 2017, 20:46   #21
aja8888
aja8888's Avatar
I'm still working on getting my 1971 Beetle sorted out. Six months now and I have lots to do, but I am picking away at it. When you start yours, watch out for the Chinese parts.
Old June 12th, 2017, 12:00   #22
benIV
benIV's Avatar
I'm always worried about that. I plan to try to find a resource like tdiclub for the beetle restoration and/or find some local or somewhat local guru. I'll be using your thread too. I'm really interested to see what you end up doing.
That being said, here is a list of things I need to do with my Jetta, Orville:
1. Water damage/leak in driver's side cabin area. The carpet is fairly wet after it rains so I'll be ripping up the carpet and cleaning it out.
1.a. I'm going to tear out the entire interior trim, clean it up and replace it. In this replacement time I'm thinking of reupholstering the seats or getting leather seats. I'm not sure what my options are. More research on the forums are needed.
2. I'm still running the original everything. I am going to replace/upgrade the suspension; from the shocks/struts/springs to the cabs and tie rod ends and cv boots and what not.
3. I'm worried about some noises I'm hearing/feeling. I'm worried the DMF is about to go out. I also feel like the turbo is dying. I'm preparing for a clutch/dmf replacement and a turbo replacement. All this will include other maintenance and upgrades that will be easier to do during the process of removing/replacing some of these other things. I'm thinking; IM cleaning, maybe egr delete, etc.
4. Headliner needs to be refurbished. Maybe a time for some fun cloth or some other neat idea instead of cloth?
5. I've got a ton of chips and nicks and have ordered the color doctor thing to try to fix it and make it look better. There are several chips that were fixed with a small thing of paint the dealer actually gave me. He said he just finished some bodywork on a 2003 platinum gray jetta and had some leftover paint. Needless to say, it is bluish and is obviously not the same color. It's easily noticeable.
6. I am tired of refurbishing the plastic headlights every six months after they become super dingy and blurry. I am thinking of trying to find a glass lens cover for the ones I have or replacing them. I saw the Hella ones on idparts, and they're not a terribly high price. I still have to do some more research as I've never considered buying other headlights. Euroswitch add too.
7. New wheels so i can refinish the steelies. idk if i want vw alloys or some aftermarket wheel. If I get to this poitn and have money leftover, i might just get something cheap.
Pictures and what not to come.
Old June 15th, 2017, 08:31   #23
benIV
benIV's Avatar
After some issues with Knurren, I decided to check the cooling fans and compressor engagement on Orville. All check out fine! A/C is cold too! Yay.
Old July 12th, 2017, 20:11   #24
benIV
benIV's Avatar
Autoscan, first ever. Putting the newly acquired VCDS to work. Did Knurren first, now Orville.
Results:
Wednesday,12,July,2017,22:13:48:00816
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 17.1.3.0 HEX-V2 CB: 0.4336.4
Data version: 20170320 DS267.7
www.Ross-Tech.com
VIN: 3VWRP69M13M086753 License Plate:
Chassis Type: 9M (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: 3VWRP69M13M086753 Mileage: 358180km-222562miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 00066
VCID: 629EA334CD5F82175BD-4B3C
3VWRP69M13M086753 VWZ7Z0B5882584
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 3330167027255B9FE0B-5184
Part No: 1C0 909 605 F
Component: 04 AIRBAG VW61 0202 0001
Coding: 12340
Shop #: WSC 00066
VCID: 2708F220E6FD273F4C3-5160
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 906 L
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 07232
Shop #: WSC 00000
VCID: 313C1C78D839698F927-5160
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00066
VCID: 70BAD97C13B32087DD9-5160
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 37282260365DB7BFDC3-4B1E
Subsystem 1 - Part No: 1C1959801A
Component: 1H Tőrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1H Tőrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1H Tőrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1H Tőrsteuer.HR KLO 0004
7 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180
Component: Radio ZSW 0018
Coding: 00031
Shop #: WSC 00066
VCID: 5DE490C8F421BDEF66F-5160
End----------(Elapsed Time: 07:48, VBatt start/end: 13.4V/13.6V)-----------
Old April 2nd, 2018, 18:50   #25
benIV
benIV's Avatar
The past several months Orville has sat, mostly because I injured my back and couldn’t get to the jobs I wanted to, but also because a leak appeared and I couldn’t figure it out before it made the worst damp/rotting smell in the cabin. Even running the air smelled horrible.
I felt better this past weekend so I went out and started cleaning out the underside of the cowling.
I had my windshield replaced not long before the leak started I think... maybe the person who did the work didn’t put it back together snugly or something, I’m not really sure.
Anyway, it was a mess. Here are some photos. Also, I broke the cowl at the passenger side windshield wiper hole, but I don’t know if it matters since I believe water is intended to get through. I’m going to replace it anyway.
Old break in the cover that probably aided in the accumulation of the leaves
New damage: I had no patience with this. The driver wiper arm came off easily but the passenger wiper arm was stuck good and leaning over the hood was killing my back, so I got a bit frustrated. I had already decided to replace the part, so I wasn’t too worried about it.
Here is the driver’s side. It was quite thick.
and a closer look at the same area
I cleaned it out with a shop-vac
The crap was deep on both sides before i vacuumed it out
After the vacuum I got some wet wipes and a toothbrush and got as much as I could reach. I cleaned up everywhere the cowl touched/sat and the cowl itself. I am going to replace it, but I don’t have a new one yet so I’m putting the old one back on while I find a place to buy a new one. I’ve looked a little and it’s hard to find, so I guess if I have to I’ll drive the 2 miles to the dealership.. maybe it won’t cost too much there :rolleyes
Anyway. It looks a million times better now, but I didn’t have any photos as my phone died and I was running late that day. When I replace the cowl I’ll be taking more.
Not a big job or anything, but it was satisfying to clean all that gunk up.
Old November 22nd, 2018, 21:44   #26
benIV
benIV's Avatar
Default Orville; my first TDI - 2003 GL Jetta Sedan
I’m really annoyed with the state of Orville right now. I need to get started on this ASAP before it gets worse.
I found and stopped the leak, so no more water is getting in the car but I’ve gotta clean up this car.
I started by taking out the back seats and I assume I just need to remove everything I can, get it clean, and then work from there.
My concerns are whether or not I can get all the nasty out. I’m sure others have dealt with this or worse. So any pointers would be very appreciated.
Here is the car in the current state. I'd say tragic, but it's my fault via neglect.
Old November 23rd, 2018, 09:25   #27
aja8888
aja8888's Avatar
Looks like it is ready for an "extreme makeover"! I believe on Vortex you can find a DIY on recovering the door panels. Good luck!
Old December 17th, 2018, 19:06   #28
ZiggyoftheNorth
My Jetta has a lot of little stuff wrong too. Junkyards can provide a lot of interior options. I got leather seats for mine. A lot of B5 Passat interior parts fit.
ZiggyoftheNorth is offline   Reply With Quote
Transmission lurching from a dead stop: 2003 Golf TDI (ALH/A4) perdurabo VW MKIV-A4 TDIs (VE and PD) 0 January 3rd, 2011 09:37
nozzle questions on 2003 A4 ALH westerntexan VW MKIV-A4 TDIs (VE and PD) 19 November 15th, 2009 19:56
2003 Jetta Wagon ALH gioTDI TDI Conversions 1 October 24th, 2009 22:53
2003 jetta 1.9 TDI ALH Eastsideservice TDI 101 9 April 1st, 2008 05:54
bad amplified antenna(2003 Jetta), or WHY I LOVE T spanky1 TDI 101 13 October 18th, 2005 22:04
Page generated in 0.19496 seconds with 11 queries
[Output: 134.57 Kb. compressed to 114.60 Kb. by saving 19.97 Kb. (14.84%)]
