Thanks Mach1!
My flex pipe is a little stiff, especially when compared to the factory flex pipe. Will go with Vibrant if I ever do this again.
I decided to do the individual cuts because I really didn't know how many, and what kind of bends I would need. Not to mention, the 10 foot section of 409 stainless steel was under $100.
When I do my wife's truck, it will be pre-bent pipes. I can't imagine doing all of those welds on 4 inch pipe.
I first installed the exhaust with no muffler or cat. The turbo was loud, even at idle, and the car sounded much like a strait piped Dodge Cummins when you put your foot in it. I installed a Pypes 2.5 inch stainless muffler, which produced a fantastic sound. It sounds smooth, deep, and powerful. I should have left it that way, but...
...I decided to put another cat on it. I bought a Magnaflow 94006D; I don't think it is high flow, but the folks at Magnaflow said that it was tested on a 6.2 liter diesel w/turbo, and pulling a trailer. They didn't feel that I would have any problems with it.
I still have no idea if it is the proper size?
The noise is quite a bit softer, and the exhause smell is back under control.
