Closed Thread
Old December 17th, 2008, 11:00   #16
maktas
maktas's Avatar
Originally Posted by senez
The baking part is what gets me.
What? Like cookies?
Yes, its gone past what is called a "mechanical fit" to a "atomic fit". VW designed the tolerance to be slightly undersized according to the material's thermal expansion coefficient. Once the critical temp is reached, the gear slips on and when it cools, it is as good as welded on. There is nothing like atomic bond forces to hold something together.
2005 Passat TDI GLS, ST tune (gone after GP recall flash ), Reflex Silver, aftermarket HID 5000k (both headlight and fogs), chainless as of 4/18/09
maktas is offline
Old December 17th, 2008, 11:08   #17
KALaBenne
Fuel Economy: 35.2 MPG
So I'm assuming the critical (installation) temperature is far above what would be experienced in a normal warmed-up engine?
edit: I read the PDF and I sure hope my engine never gets up to 350F
Thanks for all the hard work MoGolf and oilhammer!!
'04 B5.5V GLS TDI Retired 330K Urban Grey / Anthracite Leather
Delete - dealer, vent, chime, DRLs, Ceramic GP's, BS CHAIN
Add - auto unlock, sunglass holder
'82 MB 300D(turbo) 378K Tornado Survivor/Daily Driver
KALaBenne is offline
Old December 17th, 2008, 11:16   #18
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Well, if your engine did heat up to 350F, both the shaft and the gear would too. There would be no loosening of the gear on the shaft then. However, other not-so-nice things would become of interest at that temperature!
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline
Old December 17th, 2008, 12:27   #19
samspock
Wow, that's a nice writeup. After reading it I almost feel like I could do this myself. Good thing I know better. I like my car, I want to keep it.
'15 Jetta TDI S Black
Gone but not forgotten:
'05 Passat TDI GL Shadow Blue
'76 MB 240D "The Bird Slayer"
samspock is offline
Old December 17th, 2008, 12:46   #20
vw4life
vw4life's Avatar
Fuel Economy: 7.4 L/100km 75% city (~32 MPG US)
Yah, made me question if my local VW gurus can do it [well] too. Makes me want to take that 3600 km trip to OH's shop.
\\\ David /// 2005 B5.5V TDI Stonehenge Grey - Manual Headlamp Leveling - Aspherical Mirrors - Ventectomy trouble? - Fuel Economy - Euro trailer hitch: towing, install, safety chains, towing, wiring, euro bike rack! +Factory de-tooef's, Airlift
vw4life is offline
Old December 17th, 2008, 13:53   #21
engineerorange
engineerorange's Avatar
TDI(s): 2015 Jetta
Fuel Economy: 39/41/44
This is a thing of pure beauty. I am glad it's only 6 hours to oilhammer for me. Only at 55k miles now, and no noise yet. But this will be done no later than 80k on our passat.
2015 Jetta TDI SEL 6M, White with beige
Ask me about my aircooleds
engineerorange is offline
Old December 17th, 2008, 14:06   #22
aja8888
aja8888's Avatar
Mine has *noise* at 54K. My friend's 2005 TDI Passat wagon in Connecticut has *noise* at 31K. This is all over the park with respect to chain/tensioner wear and noise.
aja8888 is offline
Old December 17th, 2008, 16:27   #23
abctdi
abctdi's Avatar
So that I understand, the new BS asm comes with a new hex shaft? Or did you use the old one? It is interesting you mentioned the noise was eliminated, does this mean the hex shaft has minimal impact on the noise issue?
I would think that a gear system would 'preload' the hexshaft against its hexhole and eliminate any motion that could cause a strange noise.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline
Old December 17th, 2008, 19:29   #24
GreasedLightnin
Originally Posted by auntulna
Those of us with mortal mechanical skills are humbled by your collective tour de force in figuring this problem out, finding the corrective parts, and replacing them. Needless to say, I won't be doin' the fixin' around here Bobalouie! I will be in touch for eventual scheduling for the grand overhaul.
Brian and Glen. You two are truly tdi warriors. Hats off to you. I'll be making the trip to St. Louis soon.
Thanks so much for the peace of mind.
Rock on!
GreasedLightnin is offline
Old December 18th, 2008, 07:14   #25
EJS
TDI(s): 2009 Jetta
Ditto - thanks so much for all the time & effort you guys put into this.
On the upside it would seem I have some of the tools required to do the job (MOTOOL-GH0002, OHTOOL-BJ0002, & OHTOOL-BJ0001)
- who'd a thunk.
It's just my opinion & worth exactly what you paid for it.
EJS is offline
Old December 18th, 2008, 17:04   #26
Skivvies
MOGolf and OH, thanks for the initiative, dedication, and generosity in trying this setup and supplying us with these instructions.
Just as a heads up to those that will be purchasing the parts, I just placed an order for those parts listed in the procedure. For the big ticket balance shaft module, 22 are on order and should be sent from the manufacturer mid-January. 6 of these are spoken for as of yesterday. I don't know if this is fact, but this is what I was told by the VW parts dept.
Skivvies is offline
Old December 18th, 2008, 20:07   #27
outthere
Has anyone considered the following idea?
Find 6 B5 owners in your area. Buy 6 BS modules. Rent a shop for a weekend. Fly in OH/MOGolf for a weekend GTG and split/share costs.
It seems like it would be easier to fly them in and work on 6 cars at once than to have 6 cars drive a couple thousand miles RT for a repair.
I like my car and dont think its unreasonable to sink 2500-3000 bucks into a car that will make it last another 5 or more years. I'm not sure I can explain a 1700 mile road trip from MD to St. Louis though.
outthere is offline
Old December 18th, 2008, 20:18   #28
JungleDeath
JungleDeath's Avatar
Fuel Economy: Pretty Damn Good
I like the above idea but, what about their tools?
2011 JSW "$" 2000 Golf "The Burner" 2007 Suzuki DRZ 400 SM "Fart Knocker"
JungleDeath is offline
Old December 18th, 2008, 21:33   #29
Smokerr
Fuel Economy: 43.5/32/28
MOGolf and Oilhammer I can only say, my deepest admiration (and I don't give that out to anyone hardly ever).
I have now written NHTSA (two now) and VW of A (the CEO) letters as well as one to my congresswoman.
I would urge all others to do the same.
If we can't hep them with the immediate fight we can support them in other ways.
One thing I suggested is that if we have to have the timing belt done at 80k in order to change out the OP and BS, then they prorate that.
2005 Passat TDI Wagon
Smokerr is offline
Old December 19th, 2008, 06:01   #30
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Pro-rate what? The belt is reportedly now an 80k mile belt ...
see post #11
http://forums.tdiclub.com/showthread.php?t=231467
or
http://forums.tdiclub.com/showthread.php?t=229870
Svante Arrhenius 1896
Lug_Nut is offline
Closed Thread
Page generated in 0.17729 seconds with 10 queries
[Output: 128.53 Kb. compressed to 106.72 Kb. by saving 21.81 Kb. (16.97%)]
