Hi folks, tdiclub virgin seeks help. well the story is
I've been working on a b5.5 passat (pd 130) I keep getting a misfire code via vag-com @ number 3 cylinder, everything is fine compression wise. I've tried swapping the unit injectors around but still the same misfire #3 detected! checked the adjustments on the rockers for the injector travel. cam fine, lifters fine. what else could it be? any ideas anyone.
