Go Back   TDIClub Forums > Forum and Web Page Info > TDIClub and TDIClub Forum News, Issues, Problems and Suggestions
TDIClub and TDIClub Forum News, Issues, Problems and Suggestions This is the place for updates on the website and forums. This is also the spot for forum questions, comments, ideas, gripes, requests, etc. This forum is NOT for posting problems about your car. Non-topic posts will be moved or removed.
Old December 6th, 2010, 17:52   #31
NB_TDi
NB_TDi's Avatar
Fuel Economy: Best 56MPG
I haven't in a long while.
1994 Jetta 1.8 2000 Jetta TDI, 2005 Jetta 2.0, 2010 Tiguan 2.0 TFSI 4Motion, 2014 Jetta 2.0
Everytime you post a picture with PhotoBucket, a TDI gets below 30MPG.
NB_TDi is offline   Reply With Quote
Old December 6th, 2010, 18:47   #32
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
Lots of us do all the time.
Old December 7th, 2010, 05:22   #33
Growler
Got Soot Vendor
Growler's Avatar
I am in there almost nightly. its usually a fun read. and theres good TDI questions & answers occasionally too..
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Growler is online now   Reply With Quote
Old December 19th, 2010, 12:42   #34
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Thumbs up Suggestion/Request
Why can't the time to make corrections and changes be lengthened for a
couple of more minutes? Two minutes for this old duffer is not enough!
When you are older and never learned to type properly, any extra time would be appreciated.
Thanks for considering my request.
Regards,
D
2010 JSW. Reflex Silver/Titan Interior. A TDI with DSG.
Dynoed 132 HP, 230 ft/lb torque at the wheels.
Traded the VW for a Mercedes Benz W-211 E-320 CDI 12-17-2011.
Dynoed 12-01-12 211 HP, 386 ft/lb torque at the wheels.
View my MBZ E-320 CDI Fuelly: http://www.fuelly.com/driver/derrelhgreen/E320
Compare our previous VW TDI JSW DSG Fuelly : http://www.fuelly.com/driver/derrelhgreen/Jetta
Derrel H Green is offline   Reply With Quote
Old December 19th, 2010, 12:49   #35
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
When you get booted out, you can always pick a different name.
I'm assuming you picked a name that's already in use, or something?
Unfortunately, I don't believe that setting can be changed, though. Wasteland (the network that #tdiclubchat is on) is run by different people from #tdiclubchat, and what you're talking about is a server setting.
Originally Posted by Upton Sinclair
It is difficult to get a man to understand something, when his salary depends upon his not understanding it!
bhtooefr is online now   Reply With Quote
Old December 19th, 2010, 18:15   #36
BKmetz
Administrator, Member #10
BKmetz's Avatar
Fuel Economy: 50 MPG
Just to compliment what Tooef said; TDIClub and TDIClub chat are two separate and autonomous entities that only share a common name.
Every once in a while someone will use the TDIClub support email about a problem with TDIClub chat. Sorry, we can't help you with that one.
Brian, 2015 Passat SE TDI 6MT
Kathy, 2014 Passat SE 2.5
Chris, 2015 Passat SEL TDI
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old December 26th, 2012, 17:09   #37
thebigarniedog
Master of the Obvious
thebigarniedog's Avatar
How does one access tdichat on the new samsung google chromebook (which does not support Java).
PAGING BHTOOEFR ............
When interviewed about why no diesel for the new F150, Ford responded to effect that diesel makes no sense in the 1/2 ton market. That brilliance should be repeated in every Ram 1500 eco-diesel commercial.
OCD TDICLUB MEMBER # 1
thebigarniedog is offline   Reply With Quote
Old December 26th, 2012, 20:51   #38
Danielg42
Danielg42's Avatar
You should be able to use http://www.mibbit.com/ on your chromebook, and use the settings mentioned previously.
Originally Posted by scurvy View Post
In case you missed it from the above posts, the chat room server is irc.wasteland.org and channel #tdiclubchat.
Danielg42 is offline   Reply With Quote
Old December 28th, 2012, 17:51   #39
thebigarniedog
Thank You!
Old June 9th, 2014, 18:15   #40
Good Ol' Boy
VeeDubTDI's Avatar
We are changing chat servers!
Please reconfigure your IRC client to use irc.tdicommunity.com. Port 6667 for plain-text or 6697 for SSL. We'll be in #TDIClub.
Old June 15th, 2016, 12:50   #41
pkhoury
That guy with the goats
pkhoury's Avatar
Is anyone still using TDIclub IRC?
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old June 15th, 2016, 16:50   #42
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
Definitely, it's one of the more active IRC channels I'm in.
Old June 15th, 2016, 19:15   #43
waltzconmigo
TDI(s): none
sorry for the seemingly luddite question, what are irc channels? actually by most today I may qualify under that category.
ciao,
waltz
waltzconmigo is offline   Reply With Quote
Old June 15th, 2016, 19:26   #44
burpod
teh stallionz!!1
burpod's Avatar
google "irc channel"
82 rabbit AHU 17/22 26psi ported head, 11mm pump, pp764s, franko6 cam, custom ce2 wired, vwmikel tuned
1998 jetta AHU 17/22 26psi pp764s etc
vwmikel tuned
88 scirocco
AHU 2056vl build... delayed...05 jetta tdi & 06 golf tdi
burpod is offline   Reply With Quote
Old June 16th, 2016, 14:58   #45
Good Ol' Boy
VeeDubTDI's Avatar
Yes the IRC channel is still quite active.
http://www.tdiclub.com/chat
You might want to bookmark that link for when Fred upgrades the forum software to Xenforo. When that happens, expect a weekend-long outage of the TDIClub forums.
Page generated in 0.16671 seconds with 10 queries
[Output: 129.72 Kb. compressed to 107.84 Kb. by saving 21.88 Kb. (16.87%)]
