Old October 15th, 2019, 13:43   #1
03GolfTDI
Default Replacing wiper arms - 2012 JSW
So side effect of sitting idle while my '12 was in diesel purgatory is that the black wiper arms took a sun bath beating, was not terribly noticeable 6 months ago but multiple car washes later the paint on them is starting to flake off. The arms themselves are not too terribly expensive (maybe $110-$120 for both - OEM VW) or I could just yank them and paint them.
Has anyone pulled these before to paint or replace? My concern is the difficulty getting them off the spline due to limited clearance with the hood in the way.
Adam
'12 Jetta Sportwagen TDI DSG - 69k
Platinum Gray/Titan Black
'11 Jetta Sportwagen TDI DSG - 52k
Candy White/Beige
03GolfTDI is offline   Reply With Quote
Old October 16th, 2019, 08:40   #2
andreigbs
You should open the hood first, as high up as possible, then remove the wiper arms off the spline.
A little PB blaster works nicely.
I'd paint first, thus saving myself the $120. If that doesn't work to your liking, you can buy new ones.
2014 Jetta TDI // 44xxx miles // 38 MPG & 2014 GLK 250 // 109xxx miles // 34 MPG
2014 Golf TDI // 45xxx miles // 38 MPG - buyback'ed
2004 Bora TDI // 146xxx miles // 42 MPG - sold
1997 Jetta TDI // 317xxx miles // 44 MPG - sold
1986 Golf Diesel // 224xxx miles // 48 MPG - totaled
andreigbs is online now   Reply With Quote
Old October 22nd, 2019, 21:16   #3
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
I removed the wiper arms to run some wiring. Came off easily the first time but I had to redo something. Second time I had to get a wiper arm puller. Was pretty inexpensive and worked well. I didn’t have any problem with the hood open normally but it is a bit of a tight space.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM, RCD330plus.
Wilkins is offline   Reply With Quote
Old October 23rd, 2019, 09:19   #4
hskrdu
For that price I'd pull and paint them. Soak the bolt overnight in PB B as mentioned above, and it might be good to have an inexpensive arm puller on hand ($7 Amazon). AARodriguez' FixMyVW site (also in GA) posted a MkIV video, but there are lots of MkV videos available:
https://www.youtube.com/watch?v=hKQFxgSGuPA&t=160s
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD & 2015 GSW TDI 6M
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old October 24th, 2019, 07:44   #5
Fogcat
I too have removed arms in just such fashion. I inherited a puller. Repaint and thin no more! Just make sure you measure the gap on the edge of the arms so that they sit correctly or you may have over swipe.
Fogcat is offline   Reply With Quote
Old October 28th, 2019, 21:09   #6
where2
where2's Avatar
Back >25 years ago, I pulled the wiper arm (yes there was only one wiper arm and wiper for the windshield) off my '80 Scirocco, because it was sun faded and showing shiny metal through the black paint as described above. Part of a rattle can of Rustoleum Flat Black is all it took to look like new... At that point in life, I was a relatively "poor", starving college student. If I had to do this today on my wife's 2013, I'd rattle can it, because I have to remove the wiper arms either way, so why not paint what I already have???
'19 e-Golf SE (w/ DAP)
'13 Jetta SportWagen TDI, 6MT (4 Wife) 55k and counting...
'06 Jetta_TDI Pkg_1 5spd (wife's DD for 169k, RIP totaled)
'04 Jetta_TDI_Wagon_GL 5spd (4 daily) Got Miles... 232k!
'90 Corrado_G60 Pkg_2 5spd (4 fun) Supercharged and half the fuel economy of a TDI!
where2 is offline   Reply With Quote
Old November 3rd, 2019, 08:50   #7
03GolfTDI
Thanks everyone for the info! Will probably try the spray paint method and will definitely measure the park location (white out paint on the windshield might work well for this).
I'll let you guys know how it goes!
Adam
Candy White/Beige
2012 Wiper Arms jcayce VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 October 5th, 2012 05:45
New Beetle wiper arms Helven Ink Private TDI Items for Sale/Wanted 5 February 25th, 2008 12:45
wiper arms 01nate TDI 101 1 May 21st, 2007 18:14
Cut those wiper arms off?? Snowman VW MKIV-A4 TDIs (VE and PD) 19 August 1st, 2004 08:18
Turn Signal Control Arms/ Wiper Arms Zwei Bora Tdi Upgrades (non TDI Engine related) 0 February 1st, 2002 05:11
Page generated in 0.17804 seconds with 13 queries
[Output: 80.06 Kb. compressed to 69.51 Kb. by saving 10.54 Kb. (13.17%)]
