Stick Shift
terrman
Okanagan B.C. Canada
jetta gls 02 pearl white
Could someone explain how to remove the stock shift knob?
I have taken the boot off and see a metal ring and what looks like plastic.
thanks
Ed's TDI
Victoria, BC, Canada
2001 Bora and 2016 Touareg
Once you've unattached the trim piece that holds the boot down, simply invert the boot until the metal ring is exposed, use a pair of needle-nose pliers to pry it open and remove the assembly. If you mangle the ring too badly, you may have to get a replacement or jimmy something else up. I re-used mine with the MOMO shift knob I installed.
