Old March 19th, 2013, 19:55   #1
dwheil
TDI(s): 2001 Beetle
Default Clutch Disengagement issue
I've got an 01 Beetle TDI 5 speed that runs and shifts perfect IF, I get the trans downshifted into 1st gear as long as the car is moving. There is no grinding or syncro issues while the car is stopped with the clutch down. But if I forget to shift all the way down at a stop sign I can not shift it out of gear. I have to turn the engine off, shift into neutral and then shift into gear normally. Any ideas where to start looking. I searched the threads but did not find anything addressing my problem.
dwheil is offline   Reply With Quote
2000 Jetta shifting, clutch disengagement problems Begle1 VW MKIV-A4 TDIs (VE and PD) 3 October 11th, 2012 00:29
01M 2003 Jetta Wagon TDI disengagement boatdr1 TDI 101 24 February 26th, 2011 19:14
Clutch Issue? jdhunt0 TDI 101 2 December 14th, 2010 20:17
What did I do wrong? Clutch disengagement problem veget8 TDI Power Enhancements 6 May 26th, 2009 19:14
Premature disengagement (starter) CedarTDI VW MKIV-A4 TDIs (VE and PD) 7 December 28th, 2003 10:56
Page generated in 0.13680 seconds with 11 queries
[Output: 46.63 Kb. compressed to 43.96 Kb. by saving 2.67 Kb. (5.72%)]
