Old October 26th, 2015, 20:45   #1
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Default ALH timing with non-VCDS scanner
i have did the timing belt on wifey's car last week and checked timing with snap-on MODIS and i just was hoping someone could explain the numbers it used... it doesnt use graph like VCDS.
The MODIS has what it calls "TDI dynamic timing tool" and it goes as follows:
First it asks you to verify that the car starts and idles.
Then asks if the car is up to operating temp and idling at approx 950rpm. (her car idles at ~900, if it matters)
you confirm again and it shows this:
Upper limit 77 ATDC
Actual value 75
Target value 57
Lower limit 37
so i assume that means i would be "at the top of the graph" on VCDS as is recommended but i wanted confirmation that snap-on's setup wasnt inverted for some reason. Hoping someone can fill me in on what these numbers mean so i know im actually at the right spot on the (non-existent) graph.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old October 27th, 2015, 07:52   #2
jettawreck
jettawreck's Avatar
I don't think the numbers you will get matter much, because when you graph the timing w/VCDS you first put the car into basic mode, which takes the ECU adjustments out of the picture. So unless you can do the basic mode, the timing numbers you get will be with the ECU making timing adjustments.
So many things affect timing.
2004 Cadillac SLS (wife's)
Old October 27th, 2015, 09:57   #3
Vince Waldon
Vince Waldon's Avatar
Yup, this.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is online now   Reply With Quote
who has a VCDS/scanner they'd like to use in Los Angeles? Gluca OBD Scanners 2 January 21st, 2015 17:18
Best OBDII gauge/scanner/VCDS gmcjetpilot VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 June 9th, 2014 20:45
VCDS as non VAG OBD2 scanner jmarshall OBD Scanners 2 December 7th, 2013 02:10
Where to buy a vcds scanner tool? bruca003 Ontario 2 March 25th, 2012 12:40
Metalnerd ALH Timing Belt Tools + RossTech VCDS for Rent TWeatherford Private TDI Items for Sale/Wanted 8 July 22nd, 2011 08:39
Page generated in 0.15563 seconds with 11 queries
[Output: 60.63 Kb. compressed to 55.11 Kb. by saving 5.52 Kb. (9.11%)]
