Car:
My problem is that I don't know what the various mods/changes really do.
Two examples - Eliminate the MAF and install a race pipe. Would this help eliminate the smoking issue?
Please, do offer suggestions (besides the obvious change the TB and glow plugs/sensor issue) on what might need changing/replacing.
Thanks in advance for taking the time to help this old geezer better understand what's what.
- Bone stock 2003 Jetta Wagon - 5M - 85K miles. Only have a DieselGeek aluminum skid plate as deviation from stock.
- Planning on a 4K to 5K Christmas trip to visit grand-babies and sightsee some on the way home.
- Getting replacement tires tomorrow after work - Michelin Hydroedge.
- With 85K on the clock, timing belt is coming due shortly. Wanna get this replaced before the trip. Gonna do all the rest of the usual replacements with this maintenance.
- Suspension 'squeaks' a smidgen when going over bumps.
- 'Bad' glow plugs/harness/relay - exact issue TBD.
- 'Bad' temp/level water sensor. Car runs at 190° on the temp gauge whether it's 105° or 35° outside.
- There is 'some' typical diesel exhaust smoke on hard acceleration.
- Does not use any oil. Run full synthetic and change about every 7500 - which is about every 9 months for my normal driving.
- Change the TB.
- Repair the glow plug and temp sensor issues.
- Reduce (not necessarily eliminate) smoking on hard acceleration.
- Eliminate suspension squeaks.
- Keep reliability for the next 100K.
