perrya
what is the purpose of oiling the air filter? what is a good dry AC for this car? If the flap under the AC is open when the engine is OFF (suppose to be closed) would this condition trigger an engine code? which one?
I am thinking that my MAF contamination issue is because of this. A light oily film was found on the MAF, triggered MAF codes. If I switch to a dry AC and check the flap for proper closing, this should fix the problem. Maybe I should buy a new AC housing unit? anything else to check? the MAF is fine itself.
