VailPowder
RIP, Gone But Not Forgotten
- Joined
- Apr 15, 2000
- Location
- Vail, CO, USA
- TDI
- 2005 Jetta TDI Sedan, 1998 New Beetle TDI, 2004 Jetta TDI
We are running a TDIclub special for the Colt Billet Stage 1 Cam for PD engines We will run this special until June 15, 2011
$999 for a PD Camshaft Install Kit with new Genuine Colt Cam PD Stage 1 Billet Cam
2 Year Unlimited Mileage Warranty
This will include all the parts needed:
-upgraded black lifters,
-bearings,
-bolts,
-seals,
-gaskets
Or, you can save $300 and get the cheap 'OEM' cam and install kit from kerma for $699
Do we recommend the less expensive cam?
No, not at all.
But if you want to get it the 'OEM' PD cam and install kit, our price for the kit is much lower than anywhere else I've seen on the net , for the same parts
My thinking is why buy anything less than the best cam available?
Put a great cam in and be done with it!
The Colt Cam is an upgrade over the Genuine VW Cam...and costs no more than the Genuine VW Cam.
And the new Genuine Colt Cam PD Billet in Stage 1 or Stage 2 will run smoother, add power, and will fix the problems with PD camshafts with:
- better cam lobe design,
-better hardening
-and the correct metallurgy and correct billet blank
kermaTDI is proud to be the exclusive U.S. Colt Cam Distributor
-bearings,
-bolts,
-seals,
-gaskets
No, not at all.
-better hardening
