Nevada_TDI
So, get some sandpaper and sand the ridges off of the housing while making an attempt to keep it "round", or is that not an option?
I have already read the below post, but I want to answer your question. One-half turn is not perfect in all situations, but neither is one-full turn either. What I mean is all of our vnt's due to age and machining tolerances etc., are not going to be set at the exact same place. The point is when the actuator requests boost you don't want the vanes to potentially crash shut into each other and stick that way causing potential serious damage to anything under the hood.Alright, so you're confirming that 1/2 turn off the mechanical stop is the correct place for the screw. I noticed that the CHRA I used to set mine was about 1 full turn off the mechanical stop - maybe it was set up wrong as well... Might have been refurbed at some point even though the housings were pristine.
Yesterday I shortened the actuator rod by 1.5 turns just to see what results I get - I can do it with the turbo still on the car. As suspected, spool speed was not affected at all and I started getting spikes of 2.65bar with the requested at 2.4bar. They were compensated for by the n75 as duty factor decreased to 30%, but they lasted a bit too long for my liking (over 1 second). I think I'll reset it and leave the fine tuning to when the stop screw is where it should be.
By the way, would winding the stop screw outwards induce a spike when actual meets requested? On the graph the curve is quite flat, slowly meeting requested.
Also worth mentioning, I emulated the 1400rpm test (like block 11 in vagcom) by keeping the rpm at 1400 and toggling vacuum on/off. The difference was 130mbar which should be in the right range...? What am I aiming for when it's just right?
So the next step is to find a garage where I can adjust the stop screw outwards by 1/2 turn and we'll go from there.
Thanks for the input so far, we're almost there
Personally, I wouldn't want a spike over 2400mbar on a regular basis. 2275mbar is the safe "long term" limit for the 1749v turbo aka 18-PSI for those of us not in Europe. How is a non-tuned 1749v running more than 1900mbar anyway? Your signature shows an MB not a VW, oops.Had some time on my hands today (sadly no access to a garage to adjust the stop screw) so I decided to dial in the actuator length. Logged various settings and made a few graphs to make it easier to pick the "winner":
Rod with 8 threads showing, spike at 2540mbar, N75 duty at 36%:
Rod with 7 threads showing, spike at 2650mbar, N75 duty at 31%:
I'm not getting ~20% on the N75 duty (as most guides suggest) and I'm afraid to shorten the rod below 7 threads showing since the spike could be about 2750mbar then
Original setting in the previous posts was 9.5 threads showing, it was a bit lazy there so I'd think between 9 and 8 is the sweet spot where it spikes up to 2500mbar max. Seeing as it will be mapped after it's dialed in, I wouldn't want too big of a spike as it will probably be even higher after the map...
