Thanks!
Is there a reliable source of Bosio power plus 683?
Ebay or local dealer?
I would like to have a smoke free car, so I would not go for the race 683
Guys,
I am confused now.
Asked a quote from CPC and dieselkontor.de (thank you both if you are reading this). The confusion is that I don't know which way to go.
Either bosio, or CPS's.
CPC seems for me too big - even the smallest one. Diffas just dynoed 330 from it (congratulations by the way). I am quite familier with the options in 1.9, but quite new to 2.5.
So again what would fit best to my needs? Currently I am planning bigger nozzles, straight rear mufflers, and chip. The main reason for the nozzle to keep the pump healthy and to have better fuel economy.
Later I may change turbocharger, but I really like currently that I have torque from 1100 rpm.
Also I am looking this pdf:
http://www.sevendiesel.it/public/cataloghi/Nozzles_Catalogue_2013-12_+_Updates.pdf
I asked quotes from other suppliers and I got a hint that a particular CR nozzle would fit. Looking at the PDF it has 152° spraying degrees instead of 142°.
So can somebody confirm the Bosio's parameters (nr of holes, diameter, spraying angle) to make sure they will fit (150hp AFB injectors)?
(I have 2 sets of AFB injectors, but I am looking for a set of 180 AKE inj. My only concern is that all the time the 1 injector with the sensor is missing from the set. Sellers are saying it is used to fail so others are buying only that one. Can somebody tell me what will happen if I loose that signal? Would the ECU be able to adjust "injection advance" or will it set a calculated value? I know I will not be able to log it anymore, but will there be another issue?)
Sorry for the questions, I am a newbie in this area, and locals doesn't have too much experience with 2.5 here.
