MXrider19
Im sure a lot of you know, the stock, non-monsoon stereo in the VWs is pretty lame. I have plans for an aftermarket head unit. I know what I want to put in, and I know I do not want to cut into the stock harness. I left the old unit out as it totally died when I pulled the entire dash to change and evaporator (PITA!) so I have the stock harness just dangling out of the radio slot.
What have you guys out there done for a harness, and for dash kits? I did an install on my sisters nissan 200sx and that was very straightforward with the metra harness and dash kit. But I know the VW is not that easy. Especially with the K-line/canbus. I know that if I end up shorting it to ground because I don't know what is going on, it can ruin Vag-com cables, and piss off some other modules. Where do you guys suggest harness' from? Dash kit? Do I even need a dash kit?
Thanks ahead of time.
