Irishfan1
I got a check engine code for engine rpm and I also have a rough idle on startup. I just got the car and have read some things about flashing the ecu or upgrading the ecu. Any suggestions.
I would first check the engine speed sensor and possibly replace it if not too expensive. If replacing it does not solve the issue, I would check wiring continuity back to the ECU.PO726 was the code. My rpm is around 800 and isn't erratic or nothing. When you first start the car it feels like alot of vibration from the motor though.
