sammyg
I had some complications with obdII port tuning to malone stage 2 with a flashzilla...
I tried to flash it and even with my polar fis off, it still fried the polar box... I had to pull my ecu and send it in as i was half way through the tune when the polar fis box shorted, when I got it back and installed it, still had trouble because I was unaware the polar fis box had burned up and had all sorts of lights and the car still wouldn't run.
after the removal of polar fis (they granted their warranty with a repair btw) the car ran fine...
it seems to pull nicely from 70-90mph but because of the added down time I was unsure of a difference vs stock.
I only ask because I thought the difference would be night and day but quite frankly idk if its a placebo effect and I am just demanding more out of the car or if I truly wont feel it until I go with the stage 2 w/ delete.
Is there any way for me to see any numbers on VCDS to confirm I am or am not tuned?
*edited to add* my mpg has been ~38 w/ and w/o the tune
