Old December 12th, 2012, 13:14   #31
WutGas?
WutGas?'s Avatar
Originally Posted by VeeDubTDI View Post
Tip for photographing lights: set your camera to Tungsten (the little light bulb icon).
Meh, just fix it in post-processing
WutGas? is offline   Reply With Quote
Old December 17th, 2012, 17:03   #32
Coffeemade
I need a set of those, but my pockets aren't that deep pockets for something I will barely see.
Coffeemade is offline   Reply With Quote
Old March 24th, 2013, 09:32   #33
rawcpoppa
TDI(s): Jetta TDI
Nice mod OP. Will these work on a mk6 Jetta?
rawcpoppa is offline   Reply With Quote
Old March 25th, 2013, 11:53   #34
jck66
jck66's Avatar
Dumb question (and really, not intended to start flames), but what purpose does upgrading these lights serve? Just (almost) never having to change out a bulb?
jck66 is offline   Reply With Quote
Old March 25th, 2013, 12:11   #35
compu_85
Gadget Guy
compu_85's Avatar
That and the light is a cooler temperature.
-J
Old March 25th, 2013, 12:31   #36
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Raw,
These are the same exact lights found on the one of the new Jetta's (I can't remember if it is GLI or Hybrid). But yes, they will work on your Jetta.
JCK, No offense taken. But yeah, there is that and a few other reasons.
I am a tech junkie. I love LED's because they are so much more efficient (just like my TDI). They make more light, while consuming less power.
Which is the same reason I just spent about $1,200 to upgrade to the LED taillights and HID/LED headlights. See better and be seen better.
Fixmy59bug is offline   Reply With Quote
Old April 1st, 2013, 20:34   #37
rawcpoppa
TDI(s): Jetta TDI
Thanks. Yet another mid added to the to do list.
Old April 1st, 2013, 23:59   #38
JdC Machine
JdC Machine's Avatar
Same here. I'm slowly trying to convert my ol' Dodge to all LED bulbs. There's just something cool knowing that there's more power available for other components. The white light given is crisp and a being higher on the color temp scale, produces a natural/pure white color.
Jim
2013 Passat TDi SEL
Opera Red
Titan Black
JdC Machine is offline   Reply With Quote
Old April 2nd, 2013, 13:26   #39
rawcpoppa
TDI(s): Jetta TDI
Seeing that Vw detects a low power draw as a bulb out one has to put resistors to fool the canbus into detecting a bulb being present yes?
If yes doesn't the resistor waste as much current as a halogen bulb you intend to replace?
Old April 2nd, 2013, 13:30   #40
JdC Machine
Originally Posted by rawcpoppa View Post
Seeing that VW detects a low power draw as a bulb out one has to put resistors to fool the canbus into detecting a bulb being present yes? No. Mods to the BCM (Body Control Module) through VCDS can correct the "bulb out" indication. If in the scenario that you don't have access to VCDS and want LEDs that bad then, yes, resistors would be necessary.
If yes doesn't the resistor waste as much current as a halogen bulb you intend to replace? Yes because the resistor simulates the load of a standard/incandescent bulb.
My response in red.
Jim
2013 Passat TDi SEL
Opera Red
Titan Black
Old April 3rd, 2013, 18:18   #41
rawcpoppa
TDI(s): Jetta TDI
Thanks for the clarification.
Old April 4th, 2013, 10:32   #42
jck66
jck66's Avatar
I'm a fan of the older method of "bulb out" indication: walk around the car and observe every now and then.
I find this is good for tire pressure monitoring too!
Old April 4th, 2013, 10:48   #43
compu_85
Gadget Guy
compu_85's Avatar
Hehe At least the new cars tell you which lamp is out. Older systems just threw a general bulb failure and you had to guess which one the system was grumpy about.
-J
Present:
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 29,000 miles.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 27th, 2013, 21:37   #44
SilverMerkur
Hi...
My name's Robert, and I am a technology addict.
That said, I found Vw has some LED license plate lights that I have been thinking about installing on my '13 Passat. They're pricey buggers, but they are OEM, DOT approved, should have better output than a bulb replacement LED, and should last longer.
The part number is 3AF-943-021-A. At almost $45 EACH that's a hard pill to swallow... But they appear to be a direct fit with only some minor VCDS coding required to keep the bulb out light from rearing it's ugly head.
Hello Robert, it appears that you have given VW a great idea....
As I get to learn more about my '14 Passat, once of the things I have noticed is that VW has not only added a backup camera, but has also switched to or installed the very same lights (part #) on my car. It appears to be another undocumented change for the new year.
Other rides:
'67 Plymouth Sport Fury Convertible
'85 Merkur XR4ti - modified
SilverMerkur is offline   Reply With Quote
Old August 28th, 2013, 04:51   #45
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Neat! I still want to pick up a set of these eventually.
Trusted TDI Mechanics Map || TDIClub Chat
**[deAutoKey]** MK4 Rear canbus license plate LED lights NO OBC ERROR deAutoLED.com Vendor & GroupBuy items for sale 5 September 18th, 2012 15:29
OEM VW LED License Plate Lights jaredaggie VW Passat Family (NMS and B7) TDIs (2012+) 7 July 12th, 2012 16:31
Converting to LED License Plate Lights the Easy Way ToeBall VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 June 28th, 2012 04:39
LED License plate bulbs... DieselGolf TDI 101 4 April 8th, 2012 03:30
:: ECS Tuning :: MKVI Golf LED License Plate Lights - Free Shipping !!! ECS Tuning Vendor & GroupBuy items for sale 0 November 8th, 2011 09:40
Page generated in 0.14281 seconds with 11 queries
[Output: 132.75 Kb. compressed to 111.22 Kb. by saving 21.54 Kb. (16.22%)]
