Old June 2nd, 2012, 21:57   #16
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Jason and I met up with Coffeemade tonight and got some excellent comparison shots of our stock lights compared to his with the HID retrofit. I have to say - I'm very impressed with the results! I have traditionally been anti-retrofit when it comes to HIDs, but this particular setup is something that Jason and I are both very seriously considering.
Interesting observations:
  • Beam cutoff is more defined on the halogen lights, but the cutoff is still acceptable with the HIDs.
  • Traditional HID retrofit scatter is nearly nonexistent.
  • Color temperature and light output are incredible compared to the halogen lights.
  • Oncoming intensity has increased proportionately with light output. The focus is good enough to prevent blinding - at least in my opinion while viewing from several oncoming positions.
  • Beam pattern on the road in front of you appears to be excellent - as good or better than the stock lights.
I have a lot of pictures to go through, so I probably won't have them up until tomorrow.
Trusted TDI Mechanics Map || TDIClub Chat
Old June 3rd, 2012, 06:40   #17
Coffeemade
Originally Posted by dogger37 View Post
Hate to ask the question again but can this kit help make the OEM chinese lights and/or the aftermarket LED/HID lights work?
No because this is a simple install while the chinese light are a complete replacement and need to wired correctly and coded properly. I still haven't pulled out the VAGCOM once to do anything with these lights
Yeah it was nice meeting up with you guys. I really hope you guys have luck on the Chinese LED tail lights. I still can't mentally get over the inside lights not being reverse....
So I updated my G+ gallery located here
I know you have many more that me but here are a couple:
Stopped on a hill just before I met up with VeeDubTDI and Jason
Driving down the road side by side (HID kit on left and factory H7 on right:
The stock H7 is on the left in the photo and the HID is on the right.
So these are basically all the photos I got, I wish I hadn't quit but I know Lawson and Jasen had better camera skillz than me.
I will be updating my build page with some of these same photos and hopefully I get my coilovers in this week :-) click here for the build link.
Coffeemade is offline   Reply With Quote
Old June 3rd, 2012, 08:43   #18
Niner
duplicate account, banned
Just a FYI, I used to carry around big old LiIon battery packs and HID lights for night riding trails on my mountain bikes at night. About 3 years ago, HID's, at least for our applications, became outdated, everyone switched over to LED's, which are lighter, more durable, last more than 1000 starts before the ballast burns out on you, etc.
Just saying... One day, don't know when, but Cree or Osram will come up with a kickarse LED system that will make these obsolete... if history repeats itself.
Have to say, though, the results look good.
Niner is offline   Reply With Quote
Old June 3rd, 2012, 09:43   #19
compu_85
Gadget Guy
compu_85's Avatar
Here are some of the pictures I got:
Note that both cars have the same scatter up high on the wall, the HIDs are just brighter:
I didn't expect to like these when I first read about the retrofit. They are not perfect... but the pattern is better than most of the mis-aimed, clouded over headlights on a lot of cars around here. At $100 I think I will get one of the 4300k kits to try
http://uspmotorsports.com/product_in...roducts_id=632
I think this kit works so well because the H7 lamp is laid out along the same plane as the HID lamp:
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 29,000 miles.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old June 3rd, 2012, 10:03   #20
compu_85
Gadget Guy
compu_85's Avatar
Couple more pictures.
HID:
Halogen:
-J
Old June 3rd, 2012, 10:13   #21
Niner
Is the 4300K more pure white in color, sun colored? What's the Kelvin factor on the stock headlights?
Old June 3rd, 2012, 10:16   #22
compu_85
Gadget Guy
compu_85's Avatar
4300 is closer to the halogen color.
http://www.mediacollege.com/lighting...mperature.html
Present:
Past:
Old June 3rd, 2012, 12:04   #23
Niner
So 6000k is just a slight blue tinge then. Thanks.
Old June 3rd, 2012, 14:10   #24
GoFaster
Moderator at Large
That is a pretty darn good cutoff line.
Some reflectors seem to work OK with HID bulbs, others don't - this seems to be one that does.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old June 3rd, 2012, 14:34   #25
tdiatlast
Post #19: photo 3 is OEM, photo 4 is HID.
Hid cutoff lookd higher than OEM. Also, the "oncoming" shot in photo 5, the HID is fuzzier, and looks brighter/higher.
Would the HID install benefit from aiming them lower? I know, from the factory, mine were high and I adjusted them down.
Just wondering.
2014 Passat TDI SEL DSG (returned 12/14/16)
2009 JSW TDI DSG (returned 12/15/16)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
tdiatlast is offline   Reply With Quote
Old June 3rd, 2012, 16:06   #26
compu_85
Gadget Guy
compu_85's Avatar
The cutoff is about in the same spot. What you are seeing is the scatter, both lights are aimed at about the same height, and the "scatter box" is about the same too. It's just easier to see on the HID lights.
In the oncoming shot the HID looks a bit fuzzier because the scatter light is brighter. The picture makes it look worse than it is.
Headlights are so hard to take pictures of, this is no exception. If you squint at the picture to knock down some of the brightness you can see the hotspot is in the same place.
-J
Present:
Past:
Old June 3rd, 2012, 17:34   #27
Niner
-J
Did you push "Buy it Now" yet for your set? How much room is there back behind the headlight to do an install, or does the whole front bumper have to come off like on my A4?
Old June 3rd, 2012, 18:01   #28
Good Ol' Boy
VeeDubTDI's Avatar
Haven't pressed "Buy it Now" just yet... perhaps tomorrow.
Old June 3rd, 2012, 20:16   #29
tdiatlast
compu 85: Thanks for the clarification. Now that I think about it, it makes perfect sense that a photo of a light would have issues.
Hmmm...don't press that "Buy it Now" button until you talk to me...maybe you/we can get a discount if you buy 2 sets? I'm seriously considering it...
Old June 3rd, 2012, 20:26   #30
Good Ol' Boy
VeeDubTDI's Avatar
I'll call you tomorrow!
DIY: HID projector complete Retrofit Kits JettaSportTDi Vendor & GroupBuy items for sale 147 October 16th, 2014 00:27
2012 Golf HID's in Canada ??? 8luglogic VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 April 2nd, 2012 14:59
any DIY oil change for 2012 style TDI?? dvandentop VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 March 24th, 2012 18:08
Any DIY for HID Retro Install on 11' Jetta? mact3333 Upgrades (non TDI Engine related) 6 August 31st, 2011 15:55
Jetta Mk4 OEM HID Manual Leveling comprehensive DIY Nitrowolf Upgrades (non TDI Engine related) 8 December 15th, 2005 18:38
Page generated in 0.27069 seconds with 11 queries
[Output: 140.24 Kb. compressed to 118.82 Kb. by saving 21.42 Kb. (15.27%)]
