shmcquilkin
- Joined
- Oct 28, 2002
- Location
- Maine
- TDI
- 2016 E63S estate, 1995.5 S6 avant, 1987 Vanagon Syncro GL, 1971 Westfalia
Looky here, at what I rec'd from Impex. I didn't order a pulley on the alternator, but one cameinstalled anyways . A NON-clutch-type pulley/120Amp alternator combo! Been on it for a few hundred miles with a new Goodyear Gatorback belt and it's been performing perfectly. I had to space the idler puller out with a small washer for the belt to be perfectly aligned on the idler as the new alternator pulley is a few milimeters extended from the alternator than the clutch-type one was. No biggie. I even called Impex to make sure that this was safely usable and they said yes, and they ate the cost as I had ordered one sans pulley... again and again, GREAT support and customer service!
No idea what the # on the pulley is as I just made sure that the central nut was tight (a PIA!) so could not place a stamped OEM#, sorry.
So now, though... no more pulley failures!!
