My motor jumps all over the engine bay. lol. I know I need the dog bone. I can see it from underneath. It's bad. If thats bad and the motor jumps as much as it does, I can imagine the other two not being too far behind so I want to do them all at once.Why do you think you need mounts? I hardly ever, EVER, see these fail.
Ok thanks. Yes it was covered in oil... The injector pump was leaking and made the whole thing pretty wet for a while. Maybe I'll save $100 and just do the dog bone....Is the Dog Bone covered in oil? Is there oil on the oil pan and transmission area where they join?
The bad DBs I've seen were soaked in oil. A grabbing clutch generally is contaminated with oil due to a leaky rear main seal. I've never experienced a DMF/Clutch failure, thus, I have no clue how that might appear.
Like Oilhammer stated, I've never seen the other two motor mounts worn out. I'm sure there are plenty of used ones in junk yards or on a garage shelf in member's garages.
