Kaktuss
Hi everyone. I have few questions related to Golf mk3 1.9 TDI (1Z and AHU engine codes).
1. What is the real diffrence (except ECU and imob) between 1Z and AHU engine?
2. Anyone knows the plunger travel for one of these engines or do I really need to connect with computer to check the ignition timing as said by Autodata and Haynes manual?
3. A mate has AHU engine, in idle it revs at 1200 rpm's and when you drive, has almost a total power loss at 2400 rpm's (just doesn't pull the car forward like it should). Any idea what is the problem? One thing is for sure, the previous owner did change the fuel pump. Could it be ignition timing, or the electrical part of the fuel pump? Or could it be the gas pedal with potentiometer?
I would be very grateful with answers for 2 and 3 question, cause those are the most time sensitive at the moment. Thank you all in advance.
