JETaah
Vendor , w/Business number
Here is one for the ages.
2006 BRM 187K
All dealer and a couple of indi shops have serviced the car for a good many miles.
The car came in for a camshaft change.
It was ailing from zero power and popping sound.
I figured it is the typical deformed valve lifters getting opened by the neighboring injector lobe on the camshaft syndrome.
When I opened the valve cover I was taken aghast. I've never seen an engine this sludged out. The dipstick registered full.
I pulled the oil filter and I could not see the ribs of the filter.
I pulled the oil pan and WOW :
4.5 quarts of oil that won't drain out of the pan.
OK, so WHY?
The engine has 5 broken (from wear, not lost timing) lifters.
The oil was changed 2000 miles ago and 5000 miles prior to that.
Castrol 5W40 synthetic was used and changed by a reputable foreign car service facility.
I am compelled to get this "stuff" analyzed.
Could it be the correct oil with an ungodly amount of soot mixed in to thicken it? The oil is the consistency of custard and I imagine that the pump had issues circulating it.
The turbo is whacked.
The car starts right up.
I don't even want to take it apart. YUCK!
2006 BRM 187K
OK, so WHY?
