FumbleMechanic
Ok.
First I want to thank everyone on here for all the great info and detailed info.
We just bought a 2005 Passat Wagon auto 115k on the clock maybe a month ago. Obviously BHW engine.
Car looks nice, drove nice but...
turned out whoever had it before me was a REAL hacker. Lots of crazy broken, Mickey Mouse crap. Anyways, car had that crazy chain sound so I did my homework and knew I better fix it. So I went and did the BSD.
Without this forum that was never going to happen. Took my time, came out great, got timing down perfect. Car started and ran perfect. Sooo much quieter.
Last Friday we took off and did a 400 mile road trip into the mts. Car ran great and got appr 40+ mpg, loaded up with junk.
Anyways, got home yesterday, took the car couple miles down to the store and it was acting odd, shuddering as it tried to shift, especially at 1400-1500 rpms. If I got on it a little, it smoothed out, but something was not right. Headed home thinking I would check it all out, until half way back after coming up a big hill the car just died doing 65 mph, no warning!
Cruised to side of road, stopped. Tried restarting and NOTHING! No crank, no click. Had my wife come and bring the laptop to run VCDS and NO CODES!
Now I'm like (add lots of colorful language)! Isn't this the crap people complain about VWs?!?
SO... had it towed home with AAA for free 'cause I pay them $$$ every year for times like this.
Tonight I am going to test a bunch of logical stuff.
Here is some info on what I know:
1) NEW coolant reservoir has a crack and DEFINITELY leaked onto the plugs below it. You know what I am talking about for important elec. stuff, like Crank sensor wires, etc.
Obviously this is the first point to follow. Can't believe it is leaking. It is brand friggin new with a new cap. Anyways... I bought the special adapter to pressure test the system so I will get a new tank and rent the tool to recheck it. I will follow wires and check for power, etc.
2) Last week, new fuel filter, new battery, as stated new coolant reservoir, new cam position sensor as the jerk before me had bent one of the tabs on the cam sprocket.
3) glow plug ind. comes on and goes out so fuel pump is getting power. I hear it run when I turn the key as well. I will pull line and check for good pressure.
4) All dash lights come on and go out as normal.
5) Pulled egr this morning and man is it gunked up solid. Will clean out and vacuum intake where it mounts. Did this just because I figured it needed it anyways.
6) pulled timing cover and everything looks normal. Can't believe anything can be wrong there as there was no mechanical noise or codes. But...I will recheck to be sure. ***IS IT OK TO TURN THE ENGINE OVER BY HAND USING THE CAM SHAFT BOLT?*** When doing the timing, it was quite firm just tweaking the cam with the three bolts loose. Seems like it would be really hard to turn everything over from there.
BTW all this went down with temps in the 100-105F range, between that and the coolant leak it makes me think Crank sensor or wires to it got wet and fried. Read somewhere that they don't like the heat anyways. But no codes!?!
Looking for some checks on those #1 and #2 pins.
Sorry for the long rant.
This is the first time I have posted on or about anything, ever on the internet.
We love this car.
Granted it is a new learning curve for me. I really don't want to disappoint the wife and tell her that we got ourselves in too deep with this German contraption but, as it just left me on the side of the road out of nowhere in 105 degree temps AND the damn thing is not showing any codes, I need some help on this one.
The nice thing is that I have to work on it in the gravel driveway, in the desert, in the summer... wait that isn't that great, is it?
Thanks everyone, without this forum, I would be soooo screwed.
We love this car.
