dak503
thank you for the quick replies. I love my my car.in the past 2 months I drove from nj to Miami. and from nj to myrtle beach sc. car ran great and I got high 40s mph. I hope it stays this way.
Might be a better state is you moved outYou're absolutely right. I was born and raised in CA, but you're still right, I shouldn't bash it. Yup, California has plentiful water resources right now, a strong economy, and lots of jobs. I heard Nissan is opening a new plant somewhere in Southern California. The best part is there are no threats from natural disasters such as earthquakes or fires, as you would find with other states, state income tax and property tax is low, and you can do 75mph on the freeway. So you're right - I should stop bashing CA.
Is Bloomberg Business good enough for you? http://www.bloomberg.com/news/artic...overtakes-brazil-with-companies-leading-worldYou're absolutely right. I was born and raised in CA, but you're still right, I shouldn't bash it. Yup, California has plentiful water resources right now, a strong economy, and lots of jobs. I heard Nissan is opening a new plant somewhere in Southern California. The best part is there are no threats from natural disasters such as earthquakes or fires, as you would find with other states, state income tax and property tax is low, and you can do 75mph on the freeway. So you're right - I should stop bashing CA.
Also, if you could kindly post a citation that states California has the 7th largest economy in the world (that's current within the last year), that would be most appreciated.
While it is true that cars sold in WA have to meet CARB regulations, we don't test diesels, so it really only applies to new cars, not an ongoing emissions test issue.
Well you'd definitely hate Michigan. We don't test anything. When we did it was confined to southeast MI and it was a corrupt and crime ridden mess, which is why we got rid of it.But Washington has very unCARB caveats. For example;
The following vehicles never need emission tests:
Motorcycles
2009 and newer models (All vehicles 2009-Present)
Toyota Prius and Honda Insight
All diesel powered passenger vehicles weighing less than 6,001 pounds
All diesel vehicles model year 2007 and newer, regardless of weight.
They also have a rolling 25 year rule, in that any car over 25 years old doesn't require emission testing for registration. California is stuck with the pre-1975 rule.
http://www.emissiontestwa.com/e/faq.aspx#3
What sensors are in the car that detect steering motion, and why would the ECU care (other than cheating on the EPA test)?Among other things, it senses steering motion. You haven't activated it.
I never said I "hated" anything. Just listing the examples of CARB "standards" adopted by other states. Washington is the only one I know of because I used to live there.Well you'd definitely hate Michigan. We don't test anything. When we did it was confined to southeast MI and it was a corrupt and crime ridden mess, which is why we got rid of it.
Since the emissions issue started I have been curious about the same thing. My average was always around 40 mpg, although I have seen 50 mpg on the MFI for brief periods. The highest I ever attained was on a trip from Williamsburg, VA to PA, about 48.5 mpg. In the winter I commonly average in the high 30s, humid summer days around 40, and on days with good air quality about 42.Same here. Highest I ever got was 42.6, but that was driving along I-10 between CA and TX (and I got it on 2 tanks). I usually get 36-39 on long trips, except my current trip, when the car is loaded good, along with a full roof rack - then my average is about 28. Normal everyday driving yields about 33-35
Two possibilities - there's a steering angle sensor that the stability control uses to know what way the driver wants the vehicle to go (and then there may be engine power demand changes requested by the stability control system). There's also going to be sensing of how much torque is applied to the steering, which will cause electric assist (and therefore alternator load) to be added in response, which may cause a slight increase in engine power demand to make it seamless for the driver.What sensors are in the car that detect steering motion, and why would the ECU care (other than cheating on the EPA test)?
Maybe and maybe not. I just make sure to buy plenty of fuel in AZ or NV before coming in, and change low flow showers to high flow. 2.5gpm doesn't cut it for me. The only reason my vehicle is registered in CA is because of the super cheap insurance rates I get.Might be a better state is you moved out
Steering angle sensor. Usually mounted somewhere in the column. Used in conjunction with SIR (airbag) and ABS (stability) modules, and apparently in the case of VW to assist in detecting when testing was being performed.What sensors are in the car that detect steering motion, and why would the ECU care (other than cheating on the EPA test)?
I'd try to hold off on the tires. If they drop a DEF tank and pump in where the spare tire was, they might buy you 4 new run-flat tires as compensation.So...in case there would be a buyback...how long do you think it will take before it happens?
Just asking because in the coming months i have to do brakes and tires
Tell that to the pot heads in colorado and other statesNullification is a fraud try it your cell mate will be the guy who says the income tax is unconstitutional
Thinking about this more I guess I am better waiting... If I trade now I would possibly forfeit whatever compensation I am due. I'm just angry.I have a 2014 JSW TDI with only 16000 miles on it. I love the car and I had planned to run it into the ground but now this news has changed my plans. Here is my question: should I trade now for a 2016 GSW TSI? Or am I going to be better off financially waiting for several months (or years) to see how this plays out? I could wait to see if there is a possible buyback/trade-in incentive and switch to a GSW TSI at that time. I am going to get hosed if I trade now but I'm worried I will be even more hosed if I wait and there is a recall that cripples performance. Angry that I have to even think about this.
I don't think I got much better before I got my basic Stage 1 tune. I tend to do a lot of highway driving, though. I've already been cross country on two round trips, from CA to TX about a dozen and a half times, and this particular trip has taken me from TX -> NM -> AZ -> So Cal -> Nor Cal -> NV -> UT -> ID -> WY -> CO, and today I'll go through KS and OK before going back to TX. The best mileage I got was while I was in Florida doing my graduate research. Since it's so darn flat, I was averaging about 36-39, but speed limits top out around 55mph (usually more like 45-50, but 70 on I-95).Since the emissions issue started I have been curious about the same thing. My average was always around 40 mpg, although I have seen 50 mpg on the MFI for brief periods. The highest I ever attained was on a trip from Williamsburg, VA to PA, about 48.5 mpg. In the winter I commonly average in the high 30s, humid summer days around 40, and on days with good air quality about 42.
Mine is also a 2010 Jetta, no mechanical or computer mods, just rabid home-based maintenance above some of the recommended intervals.
Go ahead and take the lead, just keep it within your state. No reason the remaining 290+ million of us in the US should be forced to follow if we don't want to. With 28 million of that living within 3 totally congested cities (SF, LA, SD) they should have nor right to "rule" the rest of the country.Im tired of the constant CA bashing and name calling.
CA has the 7th largest economy in the world, and 38.8 million people. That is eleven million more than Texas. To not take the lead in reducing emissions would be irresponsible.
With that being said, how much do run-flat tires run new? And what kinds of punctures would they NOT be able to handle? I do a lot of highway driving, on long distances. Sometimes, I might not have ANY cellphone reception for 20-40 miles at a time, so if something were to ruin a run-flat, I'm screwed. I'm also not wild about spending more than $200 per tire new for this car.I'd try to hold off on the tires. If they drop a DEF tank and pump in where the spare tire was, they might buy you 4 new run-flat tires as compensation.
It would be curious if VW went this route, and if it also required an ECM flash. Of course, DEF would be one more thing I'd have to buy. I'm assuming that the DEF sold at truck stops works in the DEF system on the Passat?I really don't see any other way around this. The cars are very space efficient, so it's otherwise hard to find a spot to put it.
They need SCR to have a prayer at getting close on meeting emissions requirements. Retrofitting an SCR system isn't as hard as some other options, as long as you're doing hundreds of thousands of them and can gain economies of scale in the production of parts. The SCR catalyst goes on after everything else, so it's a quick exhaust pipe cut and clamp to install. It has relatively little effect on other aspects of the system, so it's not likely to increase other warranty/maintenance costs by increasing load on the DPF. It will leave power, torque, and fuel economy unaffected, so owners won't be upset. It might even let them claim an increase in MPG. The only loss to us owners is the spare tire and the time while it's in the shop. I'd like a choice of $1,000 or a warranty extension for my trouble. And maybe a set of run-flat tires/wheels.
I've seen emissions per energy in other places too outside the US. I'm glad they seem to be going to emission amount per distance per vehicle model. Easier for me to followIt's worth noting that for heavy duty engines (diesels above 8500 GVWR, gassers that are not considered "passenger vehicles" above 8500 GVWR, all gassers above 10,000 GVWR), you can choose to certify either the engine or the chassis. If you certify the engine, you're held to 0.2 g/bhp-hr for US, 0.1 g/bhp-hr (or less if you want NOx credits) for California, I believe. If you certify the chassis, and it's 8500-10,000 GVWR, it's held to 0.2 g/mi (a lot more than the 0.07 g/mi a TDI is allowed, yes, but a lot LESS than the as high as 1.4 g/mi that a CKRA makes, or 2.8 g/mi that a CBEA/CJAA makes). If it's 10,000 to 14,000 GVWR, it's held to 0.4 g/mi.
I've read conflicting reports such as:I expect a flash will be able to fix the EA288 engine (2015 models)
http://pics3.tdiclub.com/data/517/820433_EA288.pdf
.Other diesel engines in the VW Group are said to carry the same software package, but without any effect on emissions output. The problem only pertains to the EA189.
In a statement released tonight, Volkswagen said its current family of Euro 6-compliant diesels (to which the EA288 belongs) are not equipped with the emissions-cheating software
Stability control (ESP).What sensors are in the car that detect steering motion, and why would the ECU care (other than cheating on the EPA test)?
If I had a TDI related remorse on the ethical side of the Emissiongate, I would never spend my money on a VW product again. If they fudged on the TDI ECU programming, what's the guarantee they don't have the same process in place for programming the gas Engines.I have a 2014 JSW TDI with only 16000 miles on it. I love the car and I had planned to run it into the ground but now this news has changed my plans. Here is my question: should I trade now for a 2016 GSW TSI? Or am I going to be better off financially waiting for several months (or years) to see how this plays out? I could wait to see if there is a possible buyback/trade-in incentive and switch to a GSW TSI at that time. I am going to get hosed if I trade now but I'm worried I will be even more hosed if I wait and there is a recall that cripples performance. Angry that I have to even think about this.
Sort of, but not really.Does all of this have to do with the recent recall they pulled on my Jetta, lost 150 rpms at highway cruising speed and boost. Now the check engine light is always coming on with code P2002. The exhaust particulate junk.
