tromano32
Guys,
maybe someone can help me... i recently replaced a bad thermostat...I put in a new BECK/ARNLEY Housing1470055 (147-0055), a new BECK/ARNLEY Oring 0390033 (039-0033) with a Stant 195' thermostat 13379.. Drove the car for about a week when I noticed about a table spoon of coolant under the car after a drive especially after its been up to temp and built pressure... so I thought I screwed up the o ring so I removed everything, cleaned the spot where oring seats with scotch brite pad re installed and attempted to torque it down to spec but the bolt just keeps tightening and doesn't seem to go over 10ft/lbs ... when I try a ratchet is seems impossibly tight but torque wrench just wants to keep letting me tighten... what should I do next?
I am pretty sure the car did not leak before replacement because I bought it, drove for about 2 months with bad t stat ( wouldn't get over 160') and then did repair...
