Old September 25th, 2010, 21:07   #61
MadGTI
I'm surprise there is still no after market kit to replace the plastic gears!!!!
Mine just went the other day so i'm hoping i can just flip the gears out like Jenettless
MadGTI is offline   Reply With Quote
Old October 7th, 2010, 18:04   #62
Darth Scott
Darth Scott's Avatar
TDI(s): 2002 JSW TDI
Question
Originally Posted by oilhammer View Post
FWIW, my 240D, which has no EGR at all, also has a throttle plate connected mechanically straight to the accelerator pedal.
Now I'm curious... if it's not controlling the EGR, what is that throttle doing? Is that acc pedal also, as I would expect, mechanically connected to the fuel delivery system? Try as I might, the only reason I can think of for this is to bring the engine RPMs down more quickly, meaning the throttle plate restricts intake when the acc pedal is released... is that how it operates?
TIA for expanding my education, I'm really interested in this.
2006.5 w/ DSG, "Diesel Edition"
Darth Scott is offline   Reply With Quote
Old October 8th, 2010, 05:48   #63
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
An MB expert could possibly explain better than I, but it would seem to help with noise too. It also seems to help them run better in the cold, and probably works as a better way for engine braking too. The later cars did away with this setup (and use an entirely different intake as well).
The vacuum-controlled DFI systems MB used to use way back when on their diesels really works more like a carburetor by using the throttle to force a vacuum (low pressure) in the intake which is how the fuel control rod was operated. There was no mechanical linkage from the accelerator pedal to the pump, the pedal just went to the throttle.
oilhammer
www.cardocautomotive.com
Old October 8th, 2010, 16:50   #64
Greg Roles
Greg Roles's Avatar
I can't comment on what you guys have, but in my Euro model the EGR runs from it's own 3D map. The tuner I am working with found this for MKV TDI's with the EDC16+ ecu. Whilst this is indeed for the valve itself, information from Erwin suggests the flap also runs on it's own 3D map, and it's sole function is to create vacuum prior to the EGR valve to draw in exhaust.
I pulled the plug on my flap, and whilst it threw an error code and the car went into a limp mode and was obviously more "flat" performance wise, this cleared when plugged back in and error code removed via Vag Com.
Whilst unplugged the only difference I noticed apart from lowered performance was a bit of run on when shutting down. Engine braking, the one thing I'd expect a flap to play a part in, was identical. In my minds eye, this thing just pulls in exhaust gas, aids smooth shutdown, and is also used to help DPF regeneration when the car does one, for those like me hobbled with a DPF.
Ultimately I'm about to do away with mine altogether, and run a simple open / close shutdown / runaway flap just to be safe. I'll let you know what happens!
Greg Roles
2015 Skoda Yeti TDI 4x4
Greg Roles is offline   Reply With Quote
Old October 8th, 2010, 17:07   #65
2footbraker
2footbraker's Avatar
Mine had nearly identical performance when unplugged. Aside from the slightly bumpy shutdowns and also exaggerated another boost issue I'm having. But my CEL persisted after plugging it in and need to be cleared with VCDS.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Old May 7th, 2011, 10:55   #66
muellgre
TDI(s): '06 Jetta
I believe I am having the same problem as the OP and many others in this thread, but want to try to verify this is the part I need because of the cost. I have an '06 Jetta TDI PD and have read a P2112 Throttle Actuator Stuck Closed after the CEL came on. The CEL is off/on depending on the day, but it is on most of the time. I do not hear any noise from the flapper motor as others have and I have noticed no performance or mileage difference (I drive 200 highway miles a day). I removed the tube going into the flapper valve housing and can see the valve and move it by hand (although I can feel the resistance of the gear). I read on this site that the flapper valve should close for a few seconds when the engine is shut off. I had my daughter start the car for a few seconds and shut it off while I was watching the flapper and it never moved. Can anyone verify that this flapper should in fact close after every time the motor is shut off? I don't mind trying to replace this part myself, but I hate to order the part and find out it's the EGR or some other problem. Thanks.
Gregg
muellgre is offline   Reply With Quote
Old May 7th, 2011, 15:42   #67
2footbraker
Yes, it should close when you shut off the ignition and then it will open after a couple seconds.
Old May 16th, 2011, 13:36   #68
muellgre
TDI(s): '06 Jetta
I have installed the new ASV valve purchased from ECS tuning, but am still getting the same P2112 error code. First I have to say how easy it was to install this part, only took about 20 minutes and I want to thank all the members who described the process.
After I installed the new part, I left the tube disconnected to observe the flap valve while the engine was started and shut-down a couple of times. Again I did not see the valve move at all. I put the tube back on and decided to take it for a drive to see if the CEL stays off. It came on after about 10 miles of light in town driving. By the way, I did NOT clear the fault with a scan tool, but have discovered that performing the maintenance reset with the trip odometer and minute button turns off the CEL for a while, but it comes back on after a few trips with the car.
Does anyone have any advice on where I should be looking next? I'm still confused by the flap not closing when the engine is shut-down but I have no idea where to go next with this problem. Am I looking at something in the EGR? What is the EGR and it's function? Could the EGR be preventing the flap from closing on engine shut-down? Is it difficult to diagnose and/or replace?
Old May 20th, 2011, 00:15   #69
slidewayz
TDI(s): 06 Jetta TDI
I followed Jenettles? instructions - but without pics of knowing where and when to drill I smashed the plastic gear into 3 pieces - then saw where I needed to drill. Regardless, after gluing it back together - it works still. I have some basic pics, but at least they will help future fixers save themselves the $200-$600 depending on if they DIY or not.
My cost was $0. Time was over an hour all said and done.
I'd like to attach the pics - but don't know how. Can someone help?
slidewayz is offline   Reply With Quote
Old September 10th, 2011, 15:40   #70
eldar2000
TDI(s): 2006 Jetta
I have the same problem that led me to this forum. The engine light on for code P2112(TAC systems - stuck closed). Thanks for the info everyone! I took the hose off today to see what was going on and the flap was not moving. I tried moving it and it wouldn't. I turned the car on and then shut it off and ran back to see if I can see the flap move/close, but it was not moving even though I could hear the motor working. I tried it again and this time gave the flap a bit of help to see if it will close. It did, but after another try it still would not close. Feels like the gears are stripped. I put hose back on until I have more time to work on it. The light is gone though!
Can I expect the light to come back on and if it doesn't can I be pretty confident that the flap is not working properly, since it's not closing? I imagine the light comes on when the gear strips and causes the motor/flap to lock in one position, or am I completely off base here? What actually causes the sensor to trip the code?
Also, during my search for a replacement Throttle body, I ran across this:
http://www.ecstuning.com/ES475916/ES475916/ - $47.28 for the ECS model, but $289.44 for the OEM model (http://www.ecstuning.com/Search/03G128063/ES1910133/). I haven't contacted ESC yet to find out if that's really for the same part or if I'm missing something. on the one for $47.28, it says: "This product has been superseded to ES#1910133".
If that works for my 2006 Jetta I will replace it for that price just for a peace of mind!
eldar2000 is offline   Reply With Quote
Old September 10th, 2011, 15:47   #71
eldar2000
TDI(s): 2006 Jetta
Just post your pictures on any of the free places online that let you upload pictures (Picasa Web Albums, Facebook, Google for free picture upload and you'll find ton of hosting services. Once you have the pictures uploaded, use the icon and paste in the link to the picture(s) you want to post.
I would like to see the pictures, since I plan to do the DIY fix first before buying a replacement part.
Old December 16th, 2011, 19:11   #72
slidewayz
Sorry guys - I hadn't been back here in a quite a while and have since deleted the pics off my phone.
Page generated in 0.17380 seconds with 10 queries
[Output: 110.74 Kb. compressed to 93.60 Kb. by saving 17.15 Kb. (15.48%)]
