sharkie545
Car: Volkswagen jetta 06 tdi, aftermarket dash and backup camera installed.
http://www.ebay.ca/itm/Android-4-4-...721125?hash=item1a03d94825:g:6EIAAOSwFnFV-ReE
Hopefully someone can help me. I have been having battery problems in which after leaving my car off for 24hrs (5 - -2 degrees) my car will not have enough power to start in the morning. It tries to but not enough juice.
After a quick boost it works and if I turn it off at night say around 5pm - 6am it starts no problem.
Now the alternator has been tested which it is working good. the battery was tested was good but they gave me a replacement under warranty anyways. (so battery is 2 months old). They tested for power drain but said no problems everything was under normal (0.34A)
This either all started when I ran into a curb breaking my driver side wheel and the part that connects the wheel to the car. Or when I installed a backup camera which draws a 12v source (relay is installed). Or someone said it could be the canbus system in the aftermarket radio I installed (it seemed to just be a simple plug in and play sort of install - no need to enter radio code etc).
The backup camera was tested and there is no drain (no power) at all when car is off as soon as the car is turned on still nothing when in reverse there is power.
My power steering wheel light (electrical problem from what i read) kept coming on randomly but after tightening the grounding bolt under the air cabin housing it seemed to fix it (as of now).
Please hopefully someone can help me!!
