Ok folks, HPA has a multiple DSG Tunes to include a stage2 diesel, but I keep hearing about DSG tuning from Malone. I have a 140CR with APR’s stage 1 ECU, and would like some recommendations for a DSG tune. Does anybody have the HPA Tune on their TDI??? Does anybody know how does it compares to Malone?
TDI-Specific Stage 2: $649
With the TDI gaining in popularity, HPA has assembled a DSG upgrade suited to the power characteristics of this fuel efficient power plant. The DSG is a brilliant piece
of technology, and HPA has now perfected its union with the TDI engine.
Torque limit is increased from 250+ ft lbs to 360+ ft lbs. HPA’s TDI DSG software has increased the DSG gearbox’s ability to transmit torque while still ensuring the stability and capability of all the mechanical moving hardware within the DSG gearbox. If you are running performance engine software, this flash is a must to ensure the DSG can make full use of your bumped up power. Otherwise, the stock DSG software is able to override your engine software once it sees power in excess of its factory programmed 258 ft lbs torque limit.
Shift response is faster and more progressive. Through our careful command of the clutch pressures, we are able to progressively increase the responsiveness of the shifters; reducing reaction times from 0.4 sec to 0.08 seconds. Under cruising and tip throttle conditions, shift response time is approximately 30% faster than factory. From half load to full throttle, it is nearly 70% faster to respond. This means less lag when working the paddles; and more consistent and predictable shifting when you need it.
Automatic shifting in M mode is disabled. HPA gives you back true control when running in manual mode. No longer will the TDI up-shift or down-shift at inopportune times while in M mode once the annoying auto up-shift and kick down are disabled.
http://www.hpamotorsport.com/dsg-stages.htm
VS.
Additional Feature
Engine - All Engines
Tune - DSG Transmission Software Update
DESCRIPTION - Required for all American CR TDIs, all Canadian CR TDIs, and some International CR TDIs with DSG, before using any of our performance engine tunes. The factory DSG software’s torque limitation is below our Stage 1 engine torque. Without a DSG software update your shifting quality may be degraded and you will not realize the full potential of our performance tunes.Our DSG software update has the following features: Raised torque limit, gear shifts remain smooth, shift points are optimized for faster acceleration, manual kick-down mode is disabled, and in some cases launch control is added.
The DSG tune can be installed by one of our dealers (appointment required) or by renting our DSG flash tool ($2000 deposit required). Click here to see DSG flashing instructions and click here to add yourself to the DSG flash tool rental wait list.
Price - $499
http://malonetuning.com/?page_id=564
VS.
Additional Feature
Price - $499
