Stinky-D
- Joined
- May 11, 1999
- Location
- New London CT
My car recently died on the road and was towed to Reeves VW in Tampa. I quote as follows from the invoice:
"Cranks won't start
Cranks but wont start please check and advise
found vehicle was timed incorrectly and timing belt had excessive loosness causing engine to jump time. removed and replaced splash shields and engine cover, Bypass intake hose and timing belt cover. set cam in position according to vesis to rotate engine to top dead center. set injection pump to mark with pin. set t-belt and adjusted to specs. started engine and tes drove then readjusted dynamic timing to 60-120 with specs ok."
this ended up costing me 4 hours worth of labor plus the towing. the techs at reeves said that they checked and it couldn't be covered by warranty. Is this true? i've always had the vehicle maintained according to the manual. it seems that things like this shouldn't happen. Thanks for any input!
darin
"Cranks won't start
darin
