https://youtu.be/D7dUeqkMaFc This video shows the sound im talking about, not the diesel sound but the other hard to describe rhythmic sorta sound, my car makes the same sound at idle is this normal behavior for a 1.9 tdi? Thanks.
Yeah no issues, you can hear it as soon as you open the hood. Ive seen other videos with the same sound maybe normal?Yeah I agree. Sounds almost like the injectors or pump. If it’s not causing issue, I wouldn’t worry about it at this point. But I’m no mechanic, so there’s that. Is it only coming from that side? Or just in the engine bay?
Maybe, the serpetine belt is pretty loud itself it has a raspy sorta sound.You can definitely hear 2 different songs going on . First thing to do is remove the accessory belt, most likely it an alternator pulley or something like that.
Nope.Have you replaced the alternator pulley?
You were given advice to run the car without the serpentine belt. It would eliminate noises from those pulleys in the path of the belt. Have you done this to see if the sound goes away?Any ideas? Still making the sound on idle and its annoying me.
Yeah still there.You were given advice to run the car without the serpentine belt. It would eliminate noises from those pulleys in the path of the belt. Have you done this to see if the sound goes away?
