buck toenges
I have a 2000 vw tdi beetle. Have had it a very long time. I don't drive it much. My current problem is that the power door windows don't work and fuse #14 always blows. My door locks buttons work on both the driver side and passenger side. The fuel door opens with the button on the driver side. The rear hatch button does not work.
I proceeded to take off the inner door panel on driver side and disconnected the various switches. The #14 fuse still blew. I then disconnected the 2 dome lights that sit by the b pillars behind the doors up toward the top. fuse #14 still blew. I disconnected the 3 wiring harness connectors down on the kick panel behind the hood release (a blue one, a tan one and a black one) The fuse still blew.
I then disconnected the blue wiring harness connector to the ccm and then #14 fuse did not blow. I have not looked at the passenger door yet.
So I am thinking that either my ccm or switches on passenger side door or wiring harness somewhere is causing the fuse blow out. Anybody have ideas on what I should do next?
Thanks,
Buck
Thanks,
Buck
