KLXD
Fair enough. Got another car for him while you drive this one for a tank?
The only way for this to happen is for there to be a lack of air, or combustion. If there's not enough air then the fuel doesn't combust completely and exhaust smells rich.I need someone to splain to me how a Diesel can overfuel at idle without the idle speed increasing. Idle speed is determined by the amount of fuel injected. Too much fuel, too much idle speed which the ECU would compensate for.
Unless there's some kind of load on the engine. But then it wouldn't be overfueling and the one could see that with a high IQ number.
Not if it's actually the sensors lying to the ECU.If there were enough of a restriction to affect the idle like that the thing would run like ... poorly when driving.
I don't follow. How could you have an intake restriction causing overfueling at idle yet normal running on the road due to bad sensors?Not if it's actually the sensors lying to the ECU.
Sent from my moto g(7) power using Tapatalk
An UltraGauge or ScanGuarge is an excellent aid to have in these cars. You would be able to get a better idea of how the car is driven by looking at Ave MPH. This would tell you if it's idling a lot. FYI - I run mostly highway miles and my average MPH is roughly 41 (one would think it would be higher, but that's pretty much what it is and I have averaged right about 51mpg over the course of 75k miles of owning my car).
The Avg MPG on the scan gauge sits in the lower 20's... teens on acceleration and 45 when coating downhill.
Prior to the TB change (when I was driving it full time) it would average 42 mpg and that's over 6 years and 85,000+ miles. But my son started driving it at the same time I did the TB.
Nothing jumps out at me with the logging other than the MAF seems a tad bit weak, though it does seem to manage to reach the higher ranges. Tripping a code is something that ought to be addressed: perhaps the MAF is just starting to become marginal. My experience is that a bad MAF doesn't have a huge affect on FE.
I like to use the logging instructions provided on Malone Tuning's web site. It's nothing specific to them and their tunes.
Will Do!
Did you look at the injector balance as suggested in the link you posted (frank06 suggesting checking at 1,500 rpm)?
I didn't Note it down specifically, but I'll run it again to double check.
To have FE this slammed it's like there is a big fuel loss happening. Something fundamental is horribly amiss. I have only ever seen one other instance in which someone got FE that was this horrible: and, sadly, I don't recall what the cause was. Do you smell any excess fuel?
At idle, it does smell heavy with unburned diesel. It's not smoky though. I get a little bit of white smoke at cold startup and a puff of smoke when I floor it. No smoke otherwise.
No smell (or any sign of fuel leaking) when she's not running.
Is the trans being left in drive (youngster isn't manually holding gears)?
It's an 0M1 automatic (and he hasn't driven it in three months... only me).
Can anyone speak to how an improperly timed cam might play into something like this? (clearly, one can only be so far off here before it becomes extremely obvious that it's off! [bent valves etc.])
The buildup had restricted the intake input down to about 3/4 of an inch diameter. The intake ports on the head had very little buildup... maybe 1/16th of an inch?You had the intake manifold cleaned,..
was it clogged bad?
I've been working on a TDI that has what I concider mild carbon buildup in the intake manifold.
,.. and crazy carbon buildup in the head's intake ports.
I had to chip it off, couldn't even see the valve stems.
