I've finally decided all the white smoke is from bad turbo seals.
I have a replacement turbo, a turbo gasket kit from IDParts, and a new oil line from Darkside Developments.
I've got the old turbo loose - gosh that was fun.
Now how the flup do I get it out of the car?
I've been searching postings here and elsewhere for nearly an hour - lots of "remove all the bolts" threads, but they all jump from "last bolt out" to "turbo on the bench" without saying how it came out. Rrrrgh.
So once it's loose in the car:
Do you take the turbo out the bottom, maybe loosen the CV to move the axle out of the way?
Or do you take the turbo out the top, removing the intake manifold to make room?
I'm trying to avoid starting to do it one way only to find out I have to go the other. Thanks all.
